PinePhone Pro Black Screen
I flashed Arch Plasma to the emmc on my new PinePhone Pro (2024, just got in today). I used the Micro SD method and after reboot the LED turns solid green and sits at a black screen indefinitely. I have tried the RE method, flashing various images to several different micro SD cards, holding volume buttons while powering on, pretty much anything I could find online. No matter what I do it always sits at a black screen. Any help would be greatly appreciated.
(03-09-2024, 12:25 AM)CrimsenRaven Wrote: I flashed Arch Plasma to the emmc on my new PinePhone Pro (2024, just got in today). I used the Micro SD method and after reboot the LED turns solid green and sits at a black screen indefinitely. I have tried the RE method, flashing various images to several different micro SD cards, holding volume buttons while powering on, pretty much anything I could find online. No matter what I do it always sits at a black screen. Any help would be greatly appreciated.
 I was having the same problem yesterday after flashing pmOS to the emmc by the USB method. I reinstalled Tow-Boot (by microSD) and then it worked just fine.
There was a huge update to Plasma 6 earlier this month. The danctnix image may have gotten some packages updated as well (https://github.com/dreemurrs-embedded/Pi...h/releases most recent was on 3/08), but it seems to still use Plasma 5.27 (although I am running Plasma 6 on my PinePhone and it works beautifully- highly recommend to update to that when you can).
I personally had to redo the Tow-Boot instructions multiple times before I got it, so make sure to follow the volume button instructions + orders carefully.
I also just recently had an issue on both laptop and my PinePhone Pro (after updating both to Plasma 6) where the login screen was black, but I could see the mouse (on phone you will probably not see mouse cursor). If this is happening to you, you can confirm it by plugging in a keyboard to your phone, dropping to TTY (Ctrl+Alt+F3 etc), log in (default user is alarm, pass is 123456). If this works, then you are probably having the same issue I was (and many others from what I've read in other forums about this). Do
sudo pacman -S qt6-wayland
And reboot, it should work after that.
If that doesn't help, try the image from 9/25 from Danctnix.
Is it possible that the screen is faulty and is showing black?
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 596 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,542 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 5,692 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 14,993 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,674 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,838 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 4,819 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,364 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,396 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 2,265 06-26-2025, 11:47 AM
Last Post: zetabeta
