bookworm vs trixie discussion for mobian in pinephone regular.
Thank you. Now, the internal speaker does no longer work (once again). I had the same problem with the headphone but using alsamixer helped.
Please can someone show me working alsamixer settings so that I can compare them with mine to find the culprit?
P.S: I've just solved my problem, enter "alsamixer -D hw:0", press m to unmute a channel, unmute both "Line out" and "DAC", the Debian wiki gave me the hint:
https://wiki.debian.org/AlsaMixer
I still get occasional crashes when playing videos in Mozilla Firefox. The internal speaker works but when I increase or decrease the volume, there's no immediate audio feedback whereas it still works with the internal earpiece.
If you have the same sound problem than me under Mobian Bookworm, unmuting some channels will be less dangerous than switching to Mobian Trixie.
P.S: I reproduce the freeze by using the command named "play" on a simple MP3 file, VLC and Lollypop freeze too.
Exclamation
Hello
I don't reproduce the freeze with the command named "play" but Mozilla Firefox still occasionally crashes when playing a video.
Yesterday, I found how to fix the audio feedback on the internal speaker when increasing and decreasing the volume, wrong default settings seem to be applied when choosing the internal speaker as the output device, "Line out Source" gets switched to "Stereo" instead of "Mono Differential" (main root cause, breaks the feedback) and "ADC Digital DAC" is unmuted (causes a nasty noise) whereas it should remain muted. I have to manually set the correct values each time the output device changes, which is cumbersome. I'll try to modify the faulty default settings.
(02-11-2024, 05:47 AM)anonymous Wrote: Please can someone show me working alsamixer settings so that I can compare them with mine to find the culprit?
I've been trying to fix mine for months... you've just helped me get a lot closer to fixing it!!!
What number values do you have on your settings, if you don't mind me asking? When I try to unmute Mic 1 I get loud static, especially if I have the charger plugged in
Sorry for the late reply.
Headphone 100
Headphone Source DAC
Line In 43
Line Out 100
Line Out Source Mono Dif
Mic1 43
Mic1 Boost 0
Mic2 43
Mic2 Boost 0
ADC Digital DAC Muted
AIF1 DA0 40 40
AIF1 DA0 Stereo
AIF1 Slot 0 00
AIF2 DAC 40 40
AIF2 DAC Source AIF2
AIF2 DAC Stereo Mix Mono
AIF2 Digital DAC Muted
DAC 40 40
DAC Reversed Muted
Earpiece 100
Earpiece DACR
warning, t64 transition has started to affect trixie/testing.
https://micronews.debian.org/2024/1709031141.html
this makes updating little more difficult. i cannot make any good advises. but manually selecting some t64 packages is basically way to go. program "aptitude" helps.
(04-25-2024, 06:49 PM)zetabeta Wrote: warning, t64 transition has started to affect trixie/testing.
I provided some tips here: https://forum.pine64.org/showthread.php?...#pid122140
At least with aptitude you can do the following:
aptitude safe-upgrade <pkg>
Which allows you to (safely) upgrade a specific package you 'need' to upgrade.
And generally: Just read what apt/aptitude is telling you and then use common sense to decide what to do. Remember: N(o) is a valid answer.
I have just done a full upgrade and I can no longer boot Sad Please help me.
(04-28-2024, 07:10 AM)anonymous Wrote: I have just done a full upgrade and I can no longer boot Sad Please help me.
if you would be locally (physically) nearby, let's look at it. knowing what is ahead, i think best course of action is to reinstall, and temporarily i suggest other than mobian.
however:
does it boot somewhere? so you can get virtual console, i.e. ctrl-alt-f3. (usb dongle and keyboaard is required)
does it get a internet through wifi? internet is not dependent on gui.
you probably do not have sshd installed, which can be used for remote management.
software "aptitude" helps, but you still need to know some thing about packages and their dependencies.
  Printing from Mobian johnd 3 5,208 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,209 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,161 04-27-2026, 09:57 AM
Last Post: Korfou
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,492 12-23-2025, 04:34 AM
  camera not usable with trixie? JChdeL 0 1,290 12-05-2025, 01:45 AM
Last Post: JChdeL
  trixie update poll questions suggestions j_s 5 3,483 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 75,643 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,664 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 359,788 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 3,345 06-15-2025, 04:19 PM
Last Post: j_s
