Broken display connector
Trying to find a solution for the broken case, I broke also the display flat cable. I pulled it, supposing it was a connector, but it was soldered!
Now, I would like to use the HDMI interface, but there should be something to do to activate it, because when I boot, it doesn't give any signal. Anyone has an idea on what I can do?
Mick
What image are you running on your Pienbook? You may not be getting HDMI out bc it's using a BSP image instead of a mainline one.
It was Xenial version of Mate, if I remember well.
Mick
Likely it's an ayufan image, and is probably BSP. Try booting an Armbian or Debian image. They should have a more mainlined kernel with HDMI support.
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 7,128 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,867 08-03-2023, 11:43 AM
Last Post: cel
  Touchpad broken? rookieone 4 10,523 04-05-2020, 05:53 AM
Last Post: rookieone
  Pinebook battery connector and reuse binholz 2 8,509 10-17-2019, 11:05 AM
  Barrel connector replacement or repair cel 1 6,383 08-18-2019, 01:40 PM
Last Post: cel
  keyboard broken? Erik 0 3,252 05-20-2019, 02:52 AM
Last Post: Erik
  PSU broken Erik 1 5,217 06-06-2018, 04:30 AM
Last Post: pfeerick
  broken keyboard -> transplant all organs into an thinkpad? stereo 1 4,809 05-19-2018, 03:25 PM
Last Post: stereo
  Internal power connector problem stealthbanana 1 5,085 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
