broken?
Hey, newbie solder here
i bought a pinecil used it once and it was great
i whipped it out a few months later, today, to use it again and it reads low DC on the same setup as before
i tried to switch the power source but now it wont even power up? even on the setup that read low DC
tried different cubes, and cables even the barrel jack with blocks within the voltage range
i think it smells burnt or maybe it smells like a soldering iron. What gives?
Dude! The same exact thing happened to me!
I had my iron in a drawer for 3-4 months, and when I went to use it again it wasn't working. Any time I try to initiate the heating process it flashes "Low DC Voltage: 5.2V" or something similar. Initially it read something like "Insufficient Voltage" instead.
At first, I assumed I had a bad USB-QC charger, so I swapped to a battery pack that I had used successfully before. That had the exact same issue. I tested on a third USB-QC charger that I had also used it with before; same result. After playing with the settings to no avail, I tried resetting the iron to factory defaults, which did nothing. Then I updated the firmware from my desktop. Again, nothing. Finally, I plugged it into a variable DC power supply I have and tried with that. It would read the voltage change (9V), but flashed the same issue about low voltage. Even after I set the Power Delivery voltage to 9V or 0, or disabled PD entirely. Nothing had any affect.
I'd love it if anyone had any ideas for troubleshooting!
At this point though, I'm not holding my breath. This is the coolest iron I've ever used! But if I can't rely on it, then I gotta just go buy a second-hand Hakko and a cheap, 3-setting vape battery.
Thanks mates!
I am having the same issue, except in my case it stopped working the second day I had my Pinecil V2. I successfully used a USB-PD block to bring the Pinecil up to temp, then the next day it could not negotiate more than 5V. I checked the PD debug menu and it isn't leaving State 3. I realized that at least one of the cables that I tried to use had been chewed on, so it is possible that the USB-PD negotiating circuitry was damaged?
Okay fine, so I found a barrel power supply with 19V and 3.5A. The Pinecil recognizes that it has 19V, but when I put it in soldering mode, it does not heat up. The detailed view shows zero watts. I'm not sure what else to do, and nobody else that I have seen has had the same issue as me.
Did either of you try the detailed view?
  Broken pinecil (?) sh4ttered 2 6,789 02-16-2022, 01:50 AM
Last Post: sh4ttered
