How to enable XDCMP on longsleep Xubuntu?
I am using xubuntu-xenial-mate-20160528-longsleep-pine64-8GB.
How to enable XDMCP remote connections on the Pine64?
thanks!
Hey
Not sure about XDMCP - never used it - but I know that VNC works just fine on the pine as I've helped a user set it up in some time ago.
sudo apt-get install tightvncserver
Cheers
(06-09-2016, 04:27 AM)Luke Wrote: Hey
Cheers
Thanks for the suggestion. XDMCP is native to linux and unix-like systems to export the video through the network.
 But maybe VNC is a better idea. I will try, thanks.
I would assume that you want to export X11 to view X apps running on your local machine.
I've successfully done this on my Mac, but it should work on any platform that has X11 binaries for it
On the host:
Windows - install Xming
https://sourceforge.net/projects/xming/
Mac - install XQuartz
https://www.xquartz.org/
On pine (assuming you have working X11 env):
run 'xhost+' to enable all connections
should give you a message akin to "all connections are now permitted"
On your host:
1. Run X server you installed
2. SSH to Pine with -X, if using command line or if using Putty, expand SSH tab and select X11 forwarding to enable
That's it.
To test, run xeyes ;-)
(06-12-2016, 11:33 PM)gwizard Wrote: I would assume that you want to export X11 to view X apps running on your local machine.
On the host:
On your host:
That's it.
Acutally I wanted to use an Xserver program such as Xming to connect directly to the Pine64 and get the login screen. to export video i know how to do it Tongue
(06-08-2016, 09:08 PM)melao Wrote: I am using xubuntu-xenial-mate-20160528-longsleep-pine64-8GB.
thanks!
Depending on what you want to do, xrdp might also be a good solution.
thanks!
I second xrdp.  I use it along with bitvise on my windows machine and it works like a charm.
  Gentoo for pine64 - longsleep kernel incoherent 0 5,223 12-09-2017, 08:14 AM
Last Post: incoherent
  [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks moisesmcardona 3 11,437 07-27-2016, 01:16 PM
Last Post: NexusDude
  longsleep installed headers for dkms usage Faye 4 8,406 06-15-2016, 05:04 PM
Last Post: xalius
Rainbow Longsleep magic ! Lutinmalin 6 13,860 06-08-2016, 05:54 PM
Last Post: texadactyl
