Battery Power
I have 5 Pine64+ 2G models I just received today.  I am planning to build a Wimpy Cluster and starting with 5 to prototype the idea.
The inspiration came from this paper:
http://coen.boisestate.edu/ece/files/201...ter_v2.pdf
In his paper, he created a custom PCB to both power the board from the 5V input and twidle with an LED.
In my setup, I am planning to use the battery input from a standard PC Power supply instead to simplify cabling (and I see the jumper on the board to switch to battery).
The main question I have is do I need to add a ploy (or other) fuse (as he describes) to protect from short circuits?
Also, I cannot think of any reason, but I would not expect a performance decrease just because I am on battery power?
And no, I am not an EE.
Thanks,
-henry
(06-11-2016, 10:55 PM)clackamas Wrote: I have 5 Pine64+ 2G models I just received today.  I am planning to build a Wimpy Cluster and starting with 5 to prototype the idea.
Thanks,
-henry
Battery power will not decrease the board performance. The poly fuse is for cautious measure and considers a good option.
(06-11-2016, 10:55 PM)clackamas Wrote: The main question I have is do I need to add a ploy (or other) fuse (as he describes) to protect from short circuits?
Hi Henry,
Since you're using multiple pine64 boards in an array, I would be tempted to put standard glass fuses inline with the power supply line into each pine64. A polyfuse is good as it self-resets, but that can also hide a problem, unless you know that the device has triggered the fuse and why. Plain glass fuses are cheap, and if you were to put 1.5/2A fuses on each pine64, I don't see why they would blow those fuses unless something went wrong (as I have yet to see a properly working pine64 need more than 800ma @ 5v for just the main board+wifi, without the LCD or peripherals on the USB).
At an absolute minimum, you would want a single fuse between the power supply and the cluster, rated at just more than what you expect the maximum power from the cluster to be (for 5 pines, a fuse between 7.5A -10A would do), so the power supply doesn't get overloaded (although modern computer power supplies do have good self-protection circuitry in them, and generally shut down if anything goes wrong, but it's never good to blindly rely on that!).
Pete
Hi Henry,
Pete
Thank you.  That is very helpful.  I am trying to keep the cabling simple so, the glass fuses meet that criteria.  I eventually play to build a 33 node cluster but the 5 boards are to prototype.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,086 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 37,293 12-19-2020, 09:53 PM
Last Post: evilpete
  PineA64 battery in Germany (specifications or alternatives) burningkrome 0 4,910 12-02-2018, 04:10 AM
Last Post: burningkrome
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,331 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 14,930 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 27,878 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 10,576 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 50,745 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,233 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 28,404 01-07-2017, 11:59 PM
Last Post: aegrotatio
