Boot fails
Using Manjaro-ARM-plasma-mobile-pinephone-beta15-rc4.img. Booting stops and reports
"rcu: blocking rcu_node structures (internal RCU debug):"
Other OS'es boot successfully.
Any suggestions?
(10-01-2023, 01:30 AM)ionmich Wrote: Using Manjaro-ARM-plasma-mobile-pinephone-beta15-rc4.img. Booting stops and reports
Any suggestions?
Use something else is the best advice.
Manjaro Plasma is not very well supported at the moment and there are and will be issues because all updates are just pushed from upstream with little or no testing at all.
Any suggestions?
The issue might be specific to the kernel version included in the Manjaro-ARM-plasma-mobile-pinephone-beta15-rc4.img. You can try using a different kernel version or an alternative image with an updated kernel to see if the problem persists.
try a version before and then ... See https://forum.manjaro.org/t/pinephone-do...e/148470/2
recommended @Kevin Kofler and it worked for me.
That is an invalid link, and the post looks just generally like AI-generated junk.
(10-31-2023, 06:42 PM)Kevin Kofler Wrote: That is an invalid link, and the post looks just generally like AI-generated junk.
oh sorry, it hould the link shoul've been (but I do not know if same issue) https://forum.manjaro.org/t/pinephone-do...e/148470/2
did you try Beta 15 RC5? Works quite ok here. Only problem is to connect my account with nextcloud so far.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,276 10-04-2024, 12:01 AM
Last Post: spazz
  Discover Error every boot pmprog 0 2,364 11-01-2021, 03:55 AM
Last Post: pmprog
  Booted Phosh 16 Beta once and now won't boot ragreenburg 3 6,490 10-10-2021, 09:33 AM
Last Post: tckosvic
  Won't boot past the KDE splash screen nelstomlinson 5 8,555 07-10-2021, 04:46 PM
Last Post: mouffa
  After update black screen and unable to boot anything vmataixf 1 4,211 06-01-2021, 05:32 AM
Last Post: dcinoz
  Start VPN at BOOT? donniedice 2 5,268 05-26-2021, 11:52 AM
Last Post: temp0rary
Exclamation PinePhone Manjaro Edition, does not boot vdiazroa 2 5,505 11-28-2020, 02:00 PM
Last Post: bcg7
  Just tried booting up the dev release of KDE Mobile and phone wouldn't boot up. ragreenburg 1 8,149 09-11-2020, 07:34 PM
Last Post: DaveWoodX
