Network Access Error
I have installed Xenial Xerus on my pine 64 and working great. But I have problem accessing my Western Digital network drive (2 tb of MY WDWorldbook). I can able to access the same drive via my windows share. I can see my Western Digital NAS drive and when I click it gave me error. Is there anyway I can access my NAS drive directly?
Thanks.
From GUI ? if you are using the Mate de then open Caja, click the file tab and select connect to server. Type in your credentials set windows share and click connect.
Thanks. I have another question. Where is fstab located in Ubuntu Xenial Image? OR How do I add new network location or edit fstab, if I want to add? I tried sudo nano /etc/fstab and I could not find anything. I have raspberry pi 3 and I could able to edit by going to /etc/fstab.
How do I do?
(06-10-2016, 07:56 AM)coolnine98 Wrote: Thanks. I have another question. Where is fstab located in Ubuntu Xenial Image? OR How do I add new network location or edit fstab, if I want to add? I tried sudo nano /etc/fstab and I could not find anything.  I have raspberry pi 3 and I could able to edit by going to /etc/fstab.
How do I do?
I've got no issues editing fstab;  top of pic is debian on pine64 bottom is ubuntu on RPI3.
Drop by IRC (see my sig) - will be quicker to help you out.
Solved.. I used this command.
sudo vi /etc/fstab.... and I managed to edit the file.
(06-08-2016, 12:21 PM)Luke Wrote: From GUI ? if you are using the Mate de then open Caja, click the file tab and select connect to server. Type in your credentials set windows share and click connect.
I tried on my mate using Caja, I can see my all network like Apple TV, WDLXTV, EPSON Printer, Windows network and MYWORLDBOOK.
Myworldbook is my NAS drive and I can able to access this location only via windows network (that measn I have to click on windows network then select MYWORLDBOOK), so I have to keep my windows computer ON. But as soon as I shutdown my windows netwrok I cant access my NAS (Myworldbook i.e. WesternDigital 2tb, whitlight). All other network location like Apple TV, WDLXTV, I can access without windows network.
Any idea why?
  systemd-gpt-auto-generator: failed to dissect: input/output error jeanclaude.magras@gmail.com 0 4,862 12-11-2019, 04:10 PM
Last Post: jeanclaude.magras@gmail.com
  Issue with NTP (Network Time Protocol) and RTC (Real Time Clock), timedatectl emilhem 0 4,234 08-07-2017, 07:37 AM
Last Post: emilhem
  Recovering root access in Ubuntu Scientomancer 3 10,470 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Problem connecting to specific wifi network JamesWatt 1 7,337 07-03-2017, 02:09 PM
Last Post: ChristianC123
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 7,700 02-22-2017, 06:50 AM
Last Post: MarkHaysHarris777
  Error load mate desktop environment b.simp404 2 6,775 01-21-2017, 02:24 PM
Last Post: wizkidcom
  GStreamer: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server Pander 0 4,850 10-27-2016, 06:09 AM
Last Post: Pander
  dual wifi, one as access point vigor 0 3,918 09-02-2016, 11:55 PM
Last Post: vigor
  Error When Resizing SD Card Bob123456789 4 9,128 07-07-2016, 11:06 AM
Last Post: Bob123456789
  no network (dhcp) at work, all good at home. pineacle 1 4,795 06-28-2016, 10:13 PM
Last Post: pineacle
