Is my pinephone pro worth resurrecting?
In the beginning of ppp sales, I was very active in trying to get phone going to make it usable (over 125 threads).  I worked diligently on the issues of memory, battery life, sms, mms, OS/desktop software etc. In the course of this my phone got borked due to sim/sd card holder wearing out due to excessive uses.  Wouldn't even make calls any more due to sim card not connecting.  Also, I never received the replacement card holder that I applied for and pinephone promised. I put phone away for 6 months into the "about to be discarded pile".
I noticed recently that there is available a replacement motherboard that says it has a new card holder.  I am seeking advice on whether to try the new MB or just permanently disengage from the pinephone pro effort.  My old plain pinephone at least makes calls and I use that occasionally and runs for a good while.
Assuming that, if I install a new motherboard, the phone will work, where is the system performance at now? Is this the same MB that was originally installed or have some changes been made?  If MB changes were made, what is best OS/desktop software anyone has had success with?
If no changes were made and phone is back to original, am I back to all the problems that people were banging their heads against before or is there now a workable combination of OS and desktop that works well enough so that phone is usable.  If so what are the suggestions as to "current best" software combination?
I was so hoping to get a linux phone working but I am nearly burned out on this effort.
tom kosvic
(02-27-2023, 09:33 AM)tckosvic Wrote: In the beginning of ppp sales, I was very active in trying to get phone going to make it usable (over 125 threads).  I worked diligently on the issues of memory, battery life, sms, mms, OS/desktop software etc. In the course of this my phone got borked due to sim/sd card holder wearing out due to excessive uses.  Wouldn't even make calls any more due to sim card not connecting.  Also, I never received the replacement card holder that I applied for and pinephone promised. I put phone away for 6 months into the "about to be discarded pile".
tom kosvic
Don't know.  I really like it though.  We seem to be losing support. for everything.
(02-27-2023, 11:13 AM)iwm Wrote: We seem to be losing support. for everything.
Oh... that sounds not good... Sad
You mean for PinePhone Pro?
Or PinePhone in general?
Support by Pine64?
Or by the oss community (perhaps because of the conflicts between community and Pine64)?
Or both...? Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
All the support has moved to Telegram and Matrix. The community is vey much alive.
(02-27-2023, 09:33 AM)tckosvic Wrote: ...
tom kosvic
Question to anyone: is it possible to desolder and replace the existing SIM+microSD card socket from the mainboard without damaging the mainboard?
Theoretically it is possible, but maybe not in practice.
tom kosvic
The sim card slot can be repaired. I had a pin soldered on by a local repair shop. As I understand it , there are sim card slots from other manufacturers that will fit. Somewhere in these threads there are some suggestions as to which ones will fit.
tom kosvic
Did you ever get the device repaired?
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 1,982 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 2,397 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 6,825 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 19,702 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,832 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,749 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 6,464 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 4,509 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 4,719 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 3,015 06-26-2025, 11:47 AM
Last Post: zetabeta
