Broken boot: What am I missing?
Bug
Hello all!
I am currently debugging why my RockPro64 is failing to boot. I am connected via UART, and I appear to be stuck trying to grab some `boot.scr.uimg` file from the network. This happens even if I don't have an SD card inserted into the SBC, so I imagine it's something fundamentally broken.  The output is:
[color=#000000]DHCP client bound to address 192.168.1.2 (2 ms) [/color] Using ethernet@fe300000 device TFTP from server 0.0.0.0; our IP address is 192.168.1.2; sending through gateway 192.168.1.1 Filename 'boot.scr.uimg'. Load address: 0x500000 Loading: T T T T T T T T T T   Retry count exceeded; starting again Speed: 1000, full duplex BOOTP broadcast 1 *** Unhandled DHCP Option in OFFER/ACK: 125 *** Unhandled DHCP Option in OFFER/ACK: 125 DHCP client bound to address 192.168.1.2 (2 ms) Using ethernet@fe300000 device TFTP from server 0.0.0.0; our IP address is 192.168.1.2; sending through gateway 192.168.1.1 Filename 'boot.scr.uimg'. Load address: 0x2000000 Loading: T T T T T T T T T T   Retry count exceeded; starting again =>
I can drop to a shell and start doing things, but I am unsure of where to go from here. Any help would be greatly appreciated!
Well, you must have a uboot somewhere to get that output, on emmc or SPI
try (at uboot prompt) mmc list and printenv ...... see what boot_arguments are
put in a uSD and mmc list to see if it is recognized (or reboot),,,
then,,,, setenv boot_arguments mmc1 ,,, then,,, boot
you may wish to replace that uboot
there are disable emmc pins near emmc socket and SPI clock can also be shorted (to ground, this disables it)
  HDMI missing, SPI fail & continuos reboots Jack_A 0 2,787 07-26-2026, 11:34 AM
Last Post: Jack_A
  installed devuan 5/6 - missing out on resolution kapqa 0 1,680 02-20-2026, 11:36 AM
Last Post: kapqa
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,990 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 30,653 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 228,630 09-25-2023, 12:46 AM
Last Post: ChriChri
  Unable to boot Armbian on new RockPro64 mooseball 5 13,990 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,285 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,675 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 20,149 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,617 07-19-2022, 10:48 PM
Last Post: hazz
