How to play audio from ffmpeg?
Hi
System Mobian.
I run in terminal
ffmpeg -i file.wav -f alsa hw:0
but nothing is heard
How to configure?
How to switch between handset and loudspeaker?
Use -f pulse, not -f alsa. You want to output through PulseAudio/Pipewire, not directly through ALSA, because the raw ALSA device is normally already opened and reserved by PulseAudio or Pipewire. (Note that Pipewire supports the PulseAudio protocol, so -f pulse will work for both.)
(08-28-2023, 05:59 PM)Kevin Kofler Wrote: Use -f pulse, not -f alsa. You want to output through PulseAudio/Pipewire, not directly through ALSA, because the raw ALSA device is normally already opened and reserved by PulseAudio or Pipewire. (Note that Pipewire supports the PulseAudio protocol, so -f pulse will work for both.)
I did as you wrote, but still no sound.
The file is "xxx.way" or "xxx.wav"?
(08-29-2023, 08:27 AM)Gumur Wrote: The file is "xxx.way" or "xxx.wav"?
Of course xxx.wav :-) My mistake.
Unfortunately using pulse still doesn't work.
I installed Kali System and it plays sound on the speaker using alsa and pulse.
How do I switch to built-in headphones?
What do you mean by "built-in headphones"? The earpiece? Or the headphone port (but then the headphones are not "built-in", only the port is)?
The former can be selected with:
pactl set-sink-port 0 '[Out] Earpiece'
the latter with:
pactl set-sink-port 0 '[Out] Headphones'
and to switch back to the speaker, use:
pactl set-sink-port 0 '[Out] Speaker'
(08-29-2023, 07:31 PM)Kevin Kofler Wrote: What do you mean by "built-in headphones"? The earpiece? Or the headphone port (but then the headphones are not "built-in", only the port is)?
the latter with:
Yes, I mean the earpiece.
the latter with:
Thank you, it works!
It works on Kali and Ubuntu but won't work on Mobian.
I have silence all the time
Well, open up a volume control GUI (on Plasma Mobile, it is in the settings under "Audio", I don't know where it is on Phosh) and check that the earpiece is not muted and that its volume is not zero. Normally, if you set a reasonable volume once, it should remember it next time you switch to the earpiece. Though I have seen various volume control bugs resetting some volumes to zero for whatever reason, so I cannot promise that it will not end up back at zero at some point in the future.
  Modem audio settings jack1 2 4,008 02-04-2023, 04:01 PM
Last Post: jack1
  3.5mm jack audio quality? orbital 3 6,953 06-27-2022, 02:05 AM
Last Post: wibble
  scratchy phone audio KABA 3 6,241 06-24-2021, 01:15 PM
Last Post: jameslauren11
  Audio quality GloriousCoffee 5 12,248 10-24-2020, 12:00 PM
Last Post: GloriousCoffee
