How to write the the external SD card with Abword?
I have listed here problems with Abiword on the Pinephone which make it impossible to use Abiword with postmarkedOS stable:
https://forum.pine64.org/showthread.php?tid=18639
https://forum.pine64.org/showthread.php?tid=18638
The only option left here is to change the distro from postmarkedOS stable to Postmarket OS Phosh Edge, which is a lot of work. But why can I not write a file to the exernal SD card with Abiword? I can save a file to the internal SD card with Abiword, but not to to the exernal SD card. Is there a way to do it or is it an issue that Abiword cannot do this?
  How can I get the permissions to write to the external SD card ...? Peter Gamma 10 13,094 06-16-2024, 02:36 PM
Last Post: Peter Gamma
  How to create a file on the SD card I can modify on my Ubuntu PC? Peter Gamma 0 2,648 06-16-2024, 02:33 PM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 8,128 08-25-2023, 02:05 AM
  Help how to mount SD-Card chadwick 8 19,694 11-30-2021, 11:12 PM
Last Post: chadwick
  PP boots into factory test even if flashed sd card is inserted hapster 5 11,384 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal command for sd card size pnphn 5 11,993 04-02-2020, 12:51 PM
Last Post: someGermanGuy
