power/battery usage on risc-v vs arm64?
question is, has anyone any information what is battery or power usage on risc-v cpu compared to arm64 cpu? i am thinking about possible future devices with risc-v. maybe simple cellphone. i know they're not going to happen for short term though.
(08-22-2023, 01:16 AM)zetabeta Wrote: power/battery usage on risc-v vs arm64?
question is, has anyone any information what is battery or power usage on risc-v cpu compared to arm64 cpu? i am thinking about getaway shootout possible future devices with risc-v. maybe simple cellphone. i know they're not going to happen for short term though.
I'm not sure, but:
The Similarities of RISC-V and ARM:
  • Both the RISC-V and ARM are basically RISC (Reduced Instruction Set Computer).
  • Both the RISC-V and ARM use the load-store architecture. It means that data is loaded from memory, processed in the CPU, and then returned to memory.
  • Both the RISC-V and ARM support 32-bit or 64-bit instruction sets.
The Differences Between RISC-V and ARM:
  • RISC-V is an open-source architecture, whereas ARM is proprietary.
  • RISC-V support is minimal, whereas ARM support is extensive.
  • RISC-V ‘s endianness is little endian, but ARM’s endianness is bi-endian.
  PineBuds Pro: Teardown and Battery Replacement waitingpio 0 1,654 08-03-2026, 07:45 AM
Last Post: waitingpio
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 2,109 10-03-2025, 11:35 AM
Last Post: cowsay
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 2 13,033 09-03-2025, 10:51 PM
Last Post: PrinceMorissette
  Battery Life on Latest InfiniTime Build? evelynwang 0 3,664 06-03-2025, 10:26 PM
Last Post: evelynwang
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 4,081 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 4,429 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,954 04-08-2025, 08:31 PM
Last Post: colajuices
  Anyone thinking about putting a RISC-V CPU in a watch? Darin755 1 3,984 03-18-2025, 05:55 PM
  [Article] StarPro64 EIC7700X RISC-V SBC: Maybe LLM on NPU on NuttX? lupyuen 2 5,755 03-08-2025, 09:20 PM
  Pine Desktop PowerSupply wont power on BSharp 6 8,728 01-07-2025, 08:04 AM
Last Post: skare
