Long boot times? No eth?
I just downloaded this image as I have 32GB SD card. I burned it on my Mac using the following
7z x android-ver5.1.1-20160505-pine64-32GB.zip -so | sudo dd of=/dev/rdisk1 bs=1m
Popped SD into Pine64 2GB model. Powered on. Been stuck at the white/blue Pine64 logo for about 10 minutes. Is this normal?
After about 15-20 minutes (I walked away for some coffee), it was at the android desktop. Seems eth doesn't work because I have a eth cabled plugged in but android says 'Unknown' under IP address. Do I have to set this manually; no DHCP?
(06-10-2016, 09:20 AM)utdrmac Wrote: I just downloaded this image as I have 32GB SD card. I burned it on my Mac using the following
Try booting android/ remix without the ethernet cable attached during first boot. plug it in after the boot sequence finished.
Let me know if this sorted out your problem.
If it doesn't click the link in my sig - me or someone else will help you troubleshoot
Ehhh. I just tried the latest RemixOS without eth plugged in. Took even longer than Android to boot up and feels kinda sluggish in the UI. Android felt sluggish too so maybe I'm expecting too much.
Shouldnt be sluggish. Im not much of a droid guy, but I gave it a spin for good measure. For all intents and purposes it was blazing fast for me. I even played a game on it - Need for speed something something, and ran just fine albeit with poor graphics. And I feat that Remix OS was almost faster. So something may be wrong ? Let me ask the standard questions: what PSU / AWG cable are you using ? What card (precisely) are you using ?
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 5,666 01-15-2018, 11:05 PM
  Kickstarter edition wont boot to android bilbo6209 1 5,578 01-09-2018, 08:03 PM
  Boot hangs on pine64, how to debug? olh 1 5,760 08-29-2017, 12:04 AM
  Pine64+ 1G: boot loader details required Tanveer 4 11,186 07-29-2017, 09:07 PM
Last Post: Tanveer
  Pine 2GB won't boot Android anymore Bluphire 5 12,239 05-29-2017, 09:34 PM
Last Post: dkryder
  Custom boot animations Bluphire 4 9,439 05-05-2017, 02:00 AM
Last Post: Quezbeme
  Change Android boot logo? ipsw 5 17,386 05-03-2017, 09:39 PM
Last Post: Quezbeme
  Do apps run in the background at boot up? Penfold 3 7,741 03-10-2017, 02:19 PM
Last Post: mporeh
  Camera streaming to TV over long distance CanadianIceTech 6 16,196 08-03-2016, 02:15 AM
Last Post: RangeR
  Boot up issue... shadow22 9 15,571 06-23-2016, 07:44 AM
Last Post: shadow22
