Can't get ring on Manjaro Pine Phone
Hello, I can't get my Manjaro Pine Phone to ring when getting a call. I've tried everything on the phone, but please can someone tell me what I'm doing wrong. There was an update last Friday, but I don't know if that was the cause.
Chris
(06-06-2023, 03:32 AM)thorensjubilee Wrote: Hello, I can't get my Manjaro Pine Phone to ring when getting a call. I've tried everything on the phone, but please can someone tell me what I'm doing wrong. There was an update last Friday, but I don't know if that was the cause.
Chris
What desktop enviroment? Phosh, Plasma, sxmo?
Chris
Sorry, I have Manjaro Phosh.
Chris
You could install pulse audio volume control pavucontrol. This will allow you to check the profile in use and test the speakers...
Are you with regular PP (not Pro?) ?
Are you with Manjaro Phosh stable?
(There was some sound issues in Manjaro Phosh dev but new upgrade should fix them)
If you are on stable please double check that you have not toggled profile to silent/quiet from quick settings.
Also double check that you have volume on.
(06-06-2023, 10:12 AM)mark1250 Wrote: You could install pulse audio volume control pavucontrol. This will allow you to check the profile in use and test the speakers...
Thank you. I'll do that.
Chris
(06-06-2023, 11:19 AM)alaraajavamma Wrote: Are you with regular PP (not Pro?) ?
I have a regular Pine Phone and I am with Manjaro Phosh stable. I was wondering about the upgrade which we had recently. I have doubled checked that I am NOT on silent / quiet and I have the volume on.
Chris
If sound is otherwise working you might have something wrong with sound theme.
What do you get when you put this to terminal?
gsettings get org.gnome.desktop.sound theme-name
Do you have something in /home/manjaro/.local/share/sounds/
In my experience most reliable combo for callaudio (including audio in calls but also with ringtones etc.) is pipewire, pipewire-pulse and pipewire-media-session
With default pulseaudio there use to be some stability issues - most likely those are fixed - but with default pulseaudio you can't change volume levels during calls while with pipewire-pulse & pipewire-media-session combo you can.
(06-07-2023, 05:26 AM)alaraajavamma Wrote: If sound is otherwise working you might have something wrong with sound theme.
No the sound is not working! There is no ring when I get a call. I can get sound via the SD Card where I have music, and I can get that through the phone, but nothing when somebody calls me.
Chris
I kind of tried to ask that Smile.
If sound is otherwise working (like you can play music and music will be heard) can you please check:
(06-07-2023, 10:27 AM)thorensjubilee Wrote: Hello,
Chris
Downgrade calls:
sudo pacman -U /var/cache/pacman/pkg/gnome-calls-43.4-3.aarch64.pkg.tar.zst
Maybe that might help because I can see now crashes on Calls 44.something which was updated.
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,234 07-03-2024, 08:38 PM
  New phone, KDE desktop settings reset on reboot zzb0 2 6,535 10-15-2023, 10:19 PM
  Manjaro: Settings doesnt open nbh 0 3,421 09-24-2023, 05:25 PM
Last Post: nbh
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 3,200 09-24-2023, 05:18 PM
Last Post: nbh
  Is Manjaro ARM a Rolling Release? jojuma 4 7,292 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,775 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,721 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 3,545 02-09-2023, 08:17 AM
Last Post: thorensjubilee
  Manjaro plasma-mobile Beta 13 Uturn 13 17,302 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,856 11-22-2022, 05:00 PM
Last Post: Chief
