Suspend/Resume Broken with Bootloader on SPI Flash
I previously posted about having broken suspend/resume by installing tow-boot to the SPI flash.  My workaround was to just not use tow-boot and erase the SPI flash.  However recently I got an NVMe drive and installed Slackware on it.  I'd like to be able to boot from the NVMe drive directly, which I gather requires a boot loader on the SPI flash (I'd like to keep Manjaro on the eMMC if possible).
My questions are, what boot loader does the PBP/Manjaro use by default when it comes from the factory?  What is it doing that allows suspend/resume to work while other boot loaders break it?  What setups do people use to boot from an NVMe drive and have working suspend/resume?
Not possible. The NVME driver cannot successfully suspend,
so a PBP with nvme won't be able to do s2ram
(03-23-2023, 06:35 PM)xp19375 Wrote: I previously posted about having broken suspend/resume by installing tow-boot to the SPI flash.  My workaround was to just not use tow-boot and erase the SPI flash.  However recently I got an NVMe drive and installed Slackware on it.  I'd like to be able to boot from the NVMe drive directly, which I gather requires a boot loader on the SPI flash (I'd like to keep Manjaro on the eMMC if possible).
You could always keep a small /boot partition on the eMMC and install the bulk of your OS(es) on the NVMe drive. That should work, so long as the OS(es) on the NVMe drive have appropriate drivers, either compiled into their kernels or stored in their initrd files.
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,787 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 4,235 03-08-2024, 08:41 AM
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,133 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 3,346 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Testing a broken Vulkan driver LivingLinux 0 3,125 09-26-2022, 05:08 AM
Last Post: LivingLinux
  Broken eMMC boot annahellrothsparent 3 6,767 04-28-2022, 07:31 AM
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 8,496 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Working suspend on Manjaro brzegorz 3 10,281 12-03-2021, 01:39 PM
Last Post: rik-shaw
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 32,372 10-18-2021, 07:31 PM
Last Post: Syonyk
  extlinux.conf file error, can it be edited in bootloader? Abandoned Brain 2 7,082 09-26-2021, 01:28 PM
Last Post: Abandoned Brain
