Home Server with RAID 1 SATA M2 SSDs
I have been using a Raspberry Pi Model B as a home server for a decade now. Mainly as an http/cronjob server, it has never failed on me (did a SD card upgrade at some point for additional disk space). Backup was just a couple of SDs ready to replace the failing one.
Now I need more CPU power so I got myself a RockPro64 4GB and plan to setup it with two M2 SSDs in RAID 1.
My current inventory:
- board
- 60W power adapter
- PCIE to M2 SATA adapter (two slots) based on the JMB582 chip
Items I am waiting for:
- heat sink (forgot to order it with the board)
- serial to usb adapter (because apparently you cannot install Debian without it as video fails: https://youtu.be/dENsLmDhq5Y)
- 2x SATA SSDs (1TB each)
Tried installing Debian 12 but (as per the linked YouTube video) I think I got this https://wiki.pine64.org/wiki/ROCKPro64#N..._on_Debian so now I need something to hook up to the uart (please let me know if I am wrong on this).
Manjaro worked great and I was able to at least confirm the SATA adapter is loaded fine:
$ lspci
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port
01:00.0 SATA controller: Micron Technology Corp. JMB58x AHCI SATA controller
(03-19-2023, 07:18 AM)runyor Wrote: Tried installing Debian 12 but (as per the linked YouTube video) I think I got this https://wiki.pine64.org/wiki/ROCKPro64#N..._on_Debian so now I need something to hook up to the uart (please let me know if I am wrong on this).
Why not SSH into the RP64 and run the command?
I assumed the DHCP client is not enabled by default on the Debian installer as the board did not show up on my router's devices list.
What is the symptoms of your issue? Can you step by step what you have done so far? Which image? Booting from eMMC or SD?
For your setup you might find useful information here:
https://git.sr.ht/~chrichri/RockPro64_u-...RAID_howto
If your SATA controller is supported by u-boot you could finish your setup without serial console, but I'd strongly advice to be ready for failure in which case debugging via serial would be needed. Reverting to a boot from sdcard/eMMC works without serial console by disabling SPI via jumper.
Not worth setting up another account.....
Flash sector size 0x2000 ..... is this a typo? maybe 0x200?
(09-25-2023, 01:17 PM)wdt Wrote: Not worth setting up another account.....
Hm, I'm not really into that topic, but it seems that sectors used for erasing can be quiet big. Information from the SPIs data sheet (wiki) point to a size of 4096byte, but the page https://github.com/sbabic/libubootenv/bl..._config.md says it can be left out.
A quick test reveals that indeed the commands fw_* work without that parameter. I'll take it out off the howto.
0x2000 = 8K ,, this seems too low (small) for an erase block size, which is usually 64K or larger
Nowadays often 256K,, but this is NOR flash so it could be different
and after looking at the examples I think that it is indeed erase block size,, just mislabled
(03-19-2023, 07:18 AM)runyor Wrote: I have been using a Raspberry Pi Model B as a home server for a decade now. Mainly as an http/cronjob server, it has never failed on me (did a SD card upgrade at some point for additional disk space). Backup was just a couple of SDs ready to replace the failing one.
- board
- 60W power adapter
$ lspci
Sounds like you’ve got quite the DIY home server upgrade in the works! That RockPro64 setup is ambitious—RAID 1 with M.2 SSDs sounds rock solid (pun intended). As for the serial adapter, yep, you’ll need it for Debian if video fails—been there, done that, and wished for easier installs. If all else fails, and you need more power or reliability, you could always consider an affordable dedicated server from HostNoc—sometimes outsourcing the headaches is worth it! Good luck getting everything up and running!
  Anyone require a apple-sleek NAS case, w/ ample passive cooling & mutliple ssds? dairymilkbatman 0 3,558 01-19-2024, 02:17 PM
Last Post: dairymilkbatman
  Smart TV & server storz 1 4,928 01-19-2024, 01:59 PM
  Umbrel Server Shaeroden 0 4,291 05-04-2022, 06:14 PM
Last Post: Shaeroden
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 26,401 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 8,823 01-17-2021, 11:33 AM
  [WIP] backup server (4 sata HDDs + ZFS) rolando 8 19,436 06-30-2020, 10:58 AM
Last Post: dml-pc
  OMV + VPN server + Pi Hole? odhinnhrafn 3 13,491 03-16-2020, 05:01 PM
Last Post: mabs
  RockPro64 as PATA/SATA bridge? Count Omega 1 7,276 12-07-2019, 02:25 PM
Last Post: Count Omega
Video ARMBand an easily configured Home Media Server gabrielsr 2 10,617 07-22-2019, 04:56 AM
Last Post: stuartiannaylor
