Mobian + phosh firefox ublock and other overlays display bugs
hi!
i've been trying my pinephone for a while now, and i've noticed that in firefox it's almost impossible to use overlay menu's
example:
-you open ublock (default installed) and the overlay menu just flickers or doesn't size right
-if you use the toolbar menu with alt and open one of submenus  like file or tools, you get the same flicker/non display
Is there a solution to this?
i really would like to use firefox with tight ublock measures but then i need to use the menu.
(01-24-2023, 11:43 AM)tuxcall Wrote: Is there a solution to this?
No solution I know of at least Sad - Interesting: I have this annoying problem since a few months, but NOT from the beginning (with Mobian & Firefox on my PinePhone), so it has to do with an former update... I just don't know which one. Firefox? Graphics driver? Phosh...?
(At the same time context menus in Firefox got buggy for me, sometimes I can select the entry I want, sometimes it scrolls to hell and back and doesn't let me choose...)
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
I have the same issue on pmOS with both Phosh and Sxmo, so at least it's not a Phosh issue, nor a Mobian one.
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
(01-24-2023, 11:43 AM)tuxcall Wrote: hi!
example:
I also have this issue, but have a stupid work around to offer.
I set my display to 150% or 125% in phone settings and I open the menu holding the phone vertically. This exhibits the bug, but then I turn the phone sideways and it shows the controls for the NoScript plugin well enough to modify settings.
On a side note you may want to look at no script. It gives per domain control of scripting. Thus you can allow websiteyoulike.com to script but creepytrackersnoop.net can suffer without their scripts to monetize you. Other blocker add-ons do similar with curated blacklists, but noscript lets you do it by hand so it is very strict. You would be amazed how few of the domains running scripts on your computer at each website you visit require scripting for the page to work. Often sites can have ten or so domains running scripts under them, but only require the primary website's domain or the primary plus a "cdn" to function. It has a tendency to clip out advertisements and other unwanted interactions. The add-on can also catch some of the more shady operations like cross site scripting and alert you.
  Mobian MMS/SMS text problem bcnaz 16 40,054 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,709 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,609 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,934 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,840 04-29-2025, 02:10 PM
Last Post: mdk
