PPP Battery drain + hot CPU GPU
Exclamation
Hello I have received PPP few days back HK distribution Manjaro
I noticed poor  battery life
I changed OS to postmarket OS 22.06.3
Still battery drain continued :
1/ I have checked  battery capacity while charging  - it was fine
2/ I have charged 100% battery ,
closed active applications
disconnected WiFi Bt , data transfer
Screen off
put aside phone : in 2hrs 50% battery drained
Approx in 4hrs phone drains majority of battery capacity
checked CPU usage with top :  0-3% CPU utilization
3/ back case was hot under camera area
4/ metal square under camera - GPU / CPU ? was hot  with almost 0 CPU utilization.
5/ checked  temperature from system thermal_zone
CPU thermal 48,7 C
GPU thermal 49.3 C
battery 18.8 C
wonder if this is  software or hardware issue ,any advice ?
Unfortunately that's just normal for the PinePhone Pro. Mine is idling at 44C not doing anything and will easily reach temperatures of 80C under load. The battery life is poor compared to the original PinePhone which is to be expected as the PinePhone Pro has much more capable and power hungry hardware.
I don't have my original PinePhone with me otherwise I would compare the power usage and battery life between them side-by-side but from my experience I wouldn't say there's anything wrong with your PinePhone Pro, that's just how it normally is.
I have found dostribution with power management works better
  Experimental Mobian kernel patch for extended battery life teekay 15 17,013 10-27-2025, 08:43 AM
  Battery Management on PinePhonePro: d50zesl0g@mozmail.com 4 4,973 03-02-2025, 11:52 AM
Last Post: d50zesl0g@mozmail.com
  Battery life thread: discussion, support and tips apink 12 15,473 03-01-2025, 10:39 AM
  Reseting the Battery Fuel Gauge franzthiemann 8 8,907 01-24-2025, 08:19 AM
Last Post: teekay
  [Mobian] : Battery consumption and OS compatibility freelectro 2 3,872 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 5,520 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Battery meter slowly reducing under keyboard charger robocone 1 3,592 12-26-2022, 09:37 AM
Last Post: robocone
  Battery status always "Charging" dabigjhall 2 4,394 03-16-2022, 03:14 PM
Last Post: maltee
