Is it posible to put Pios on a Pine book pro
Hi
 I use the Pi os a lot. Is it possible to put it on a pine book pro.
What other Distribution option are there?
Shanta
Pi OS (formerly Raspbian) is mainly based on debian. Debian or Ubuntu (not sure if this is available for PineBook Pro) might feel similar to what you are used to.
It depends on what you do with PiOS. If you only use the graphical desktop environment, you might be perfectly happy with Manjaru. If you used the command line, then Debian will suit you just fine. Otherwise, see the wiki; there are a plethora of different operating systems you can use. BTW, many people use a Arch but I use NetBSD.
:wq
Probably with a kernel transplant
  can't login on pine pro 64 LRFritz 0 2,451 09-25-2020, 02:13 PM
Last Post: LRFritz
