Screen going black
I have encountered a new issue.  Every so often my pine will crash to a near black screen.  The lights are all still on but I can't get a response to anything I try.   It happens often while streaming video on kodi.  Sometimes it just happens when I am not running any programs.  Any suggestions as to what might be the issue?
Two things come to mind: 1) PSU / AWG of cable 2) Faulty SD card
A little bit more info about the two above would help
Same problem here with the latest release.
1) Fresh install done 30min ago
2) PSU that came with my Pine
3) Samsung EVO plus 64GB micro SD
4) WiFi module that came with my Pine
Everything is new and tested.
(05-30-2016, 04:37 AM)Luke Wrote: Two things come to mind: 1) PSU / AWG of cable 2) Faulty SD card
Sorry for the delayed response.  Had a busy week.  My sd card should be good.  It is a 64gb sandisk class 10 that I bought from Costco.  For power supply,  I am using the charger from my Samsung Galaxy note 10.1 tablet. It is 5.3V 2.0A. I understand that it is recommended to have 2.4A but I remember reading that 2.0A should be fine.  The pine is not shutting down, all the lights are all on it just goes black and freezes.
Sounds like a power issue to me.
If you could check that AWG of the cable and get back to me, that would be great. I personally had issues with a 28 AWG cable - exchanged that for 20AWG and havent had a single problem since then.
Here is what it says on the cable.
AWM 21445  80°C 30V VW-1 RFT (s)  HX NT non-pvc non-p
This doesn't mean a whole lot to me but from my Google research it seems as though the cable should support 2.1 amps.  So unless the cable has degraded it should be fine.
I have the same issue, my SD card is 100% NOT faulty and my usb wire is 20awg used for charging ecigarettes so certainly works for high powered devices
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,373 04-17-2017, 04:20 AM
Last Post: simplexdan
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,303 12-19-2016, 07:49 PM
Last Post: Toriless
  Remix touch screen support Danbrack 3 14,169 07-24-2016, 11:20 PM
Last Post: pinkelephants
  Remix OS Screen Size problem DwyerSP 2 13,113 07-02-2016, 10:44 AM
Last Post: Inuyasha
  Pine64 With HD screen? pine771 3 7,878 06-11-2016, 10:18 AM
Last Post: Wesleypjones
  Screen size issue andku85 8 16,875 04-24-2016, 03:10 AM
Last Post: dhardingham
