USB adapter to eMMC module not recognized
As I am trying to boot Pinebook Pro from a Pine64 USB adapter to eMMc module, when I plug the adapter into my Linux computer or laptop after having inserted the eMMC card into it, it is not mounted as a regular USB drive nor does it show in the file manager. The sudo fdisk -l command does not recognize it either. Therefore, neither Echer nor the dd command manually entered from a terminal can flash an OS image to the eMMC, even though the adapter's light shows when it is plugged into the computer.
As this seems to be a software issue, any hint or advice helping me to copy an OS image (e.g., Manjaro ARM or other) with the adapter from my computer or laptop to the Pinebook Pro eMMC module would be much appreciated.
whe
  eMMC empty? bluedemon382 0 2,559 07-19-2023, 06:29 AM
Last Post: bluedemon382
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,419 10-06-2022, 08:46 PM
Last Post: ihab
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,172 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to flash Focal Gnome to EMMC cyphr3x 0 3,786 06-05-2020, 02:06 PM
Last Post: cyphr3x
  How to boot from the SD card and install to eMMC? ravanh 2 10,405 03-18-2020, 09:42 AM
  USB C hub and Ethernet adapter jaysistar 3 10,526 01-20-2020, 04:07 PM
Last Post: belfastraven
  How to check eMMC? ame 5 12,965 01-08-2019, 04:31 PM
Last Post: ame
  eMMC card on adapter Malmgren 8 19,058 03-20-2018, 11:14 AM
Last Post: Malmgren
  Rock64 OS eMMC boot ProfessionalDreamer 2 8,112 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
  is my eMMC broken or am I wrong? jykeith123 8 17,410 01-25-2018, 10:27 PM
Last Post: jykeith123
