MMS workaround for users with separate APN (works atleast on Manjaro Phosh)
Hello!
While we are waiting multiplexing APN support I have tried to find out some workaround so that I don't lose MMS messages.
This is not perfect and many solutions might be wrong but hey at least it is working automated Big Grin
I am using this same script to improve battery life so all "gsettings" parts are not necessary but they make the phone suspend much much faster if screen is locked.
If you wan't to find out more about this original issue see here:
https://gitlab.com/kop316/mmsd/-/issues/5
https://gitlab.freedesktop.org/NetworkMa...issues/958
So first we need two bash scripts and lets call this first one start.sh
(Copy the text above and paste it to gedit and save it to your home folder)
#!/bin/bash gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout 60 & gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout 60 && sleep 50 && /home/manjaro/lock.sh
Then we need second one and lets call this lock.sh
#!/bin/bash dbus-monitor --session "type='signal',interface='org.gnome.ScreenSaver'" | while read x; do     case "$x" in     *"boolean true"*) nmcli c up "dna mms" & sleep 2 && gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout 5 & gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout 5;;     *"boolean false"*) nmcli c up "dna internet" & gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout 60 & gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout 60;;     esac     done
Notice that you have to use your carriers APN names and the names needs to be the same as in System settings and as in Chatty (nmcli c up "dna mms" and nmcli c up "dna internet". If the APN name is only one word you don't need to use these marks "
And then we need to add one file to /home/manjaro/.config/autostart and that will be start.desktop
(Copy the text above and paste it to gedit and save it to /home/manjaro/.config/autostart)
[Desktop Entry] Version=1.0 Name=MMS-Switch Comment=Switch MMS and Data APN regarding the lock screen status Exec=/home/manjaro/start.sh Icon=org.gnome.Terminal Terminal=falce Type=Application
Then you have to open terminal and paste
sudo chmod +x /home/manjaro/lock.sh && sudo chmod +x /home/manjaro/start.sh
Then just reboot and now you should have working MMS switch. It will switch to MMS APN when you lock the screen and when you unlock it will switch back to Data APN. And if you don't remove the gsettings parts it will suspend in 5 second when on lock screen and in 60 seconds when you are logged in and using phone Smile
Then there is one funny thing - to get all of this working you most likely need to switch to MMS APN trough System settings and then reboot (needs to do it only once). After latest updates Manjaro Phosh will switch to APN which was selected from System Settings when it resumes from suspend. I have no idea where it is coming from but this is the case at least in my scenario.
I think this should work also with Mobian and Arch but have not tested.
My skills are limited so this is not really good solution but at least it is working and I can trust that I don't miss important messages.
I suggest also to create these shortcut launchers to /home/.local/share/applications. The first one sets APN to MMS and after that starts Chatty so you can send MMS messages also. The second one just changes APN to Data so you can switch back or just relaunch internet connection if needed.
(Copy the text above and paste it to gedit and save it to /home/manjaro/.local/share/applications)
[Desktop Entry] Version=1.0 Name=Chatty MMS Comment=Change to MMS apn and open Chatty Exec=bash -c 'nmcli c up "dna mms" && chatty' Icon=sm.puri.Chatty Terminal=falce Type=Application
[Desktop Entry] Version=1.0 Name=Data On Comment=Change to Data apn Exec=bash -c 'nmcli c up "dna internet"' Icon=org.gnome.Settings-network-symbolic Terminal=falce Type=Application
I tried many other ways but this was the only one I got to work automatically. It was so much easier with PMOS where you need to add only one script to one folder Big Grin
  Fractal/Matrix MMS workaround Noob Of All Trades 11 14,708 10-04-2023, 10:59 PM
Last Post: Noob Of All Trades
  Manjaro: Settings doesnt open nbh 0 3,336 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,175 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,124 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,692 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,484 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,579 02-24-2023, 12:56 PM
Last Post: jakfish
  Can't install Manjaro thorensjubilee 1 3,492 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 17,064 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,790 11-22-2022, 05:00 PM
Last Post: Chief
