Cellular internet
ara the username and password a must for APN settings ?
 when i ping to 8.8.8.8 for example i get: "network is unreachable"
 or do i need to do or configue somathing else ?
ezik
(09-16-2022, 11:28 AM)shulamy Wrote: ara the username and password a must for APN settings ?
ezik
exacly speaking, you need to check settings from a carrier, like from the website.
for most carriers apn: "internet" works, other settings could be blank.
if you have previous device, then you could check what those settings were, sim card swapping might be required.
following link is bloated: https://android.googlesource.com/device/sample/+/master/etc/apns-full-conf.xml
this link includes default settings for average android device, because it is provided by google or device manufacturer, settings could be wrong.
ezik
 i forgot that the sim is secondary  can this be the reason?
 ezik
(09-16-2022, 03:43 PM)shulamy Wrote:  i forgot that the sim is secondary  can this be the reason?
 ezik
i don't totally get this point. pinephone has only one sim slot. do you mean secondary to wifi? networkmanager can use what's available.
you didn't say what o.s. (mobian, postmarketos, manjaro, etc) and user interface (plasma, phosh, sxmo). if plasma, i noticed that mobiledata barely works, actually it didn't. i couldn't set settings at all.
 ezik
 it's a manjaro forum and it's phosh
 secondary sim is for a car and supposed to support calls only
 ezik
(09-17-2022, 12:25 AM)shulamy Wrote:  it's a manjaro forum and it's phosh
 ezik
if operator has blocked mobile data, then it's calls only (and sms). you have to stick to the wifi (or ethernet).
 ezik
 ok. so have to replace to primery sim.
 thanks
 ezik
  Flight mode turns off wifi but not the modem (cellular) jojuma 2 4,421 02-28-2023, 01:58 PM
Last Post: calinb
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 12,226 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  No cellular connection after update on Manjaro ARM (kde) Valaki 5 8,588 12-17-2020, 02:18 PM
Last Post: Valaki
