Phosh remote desktop
Anyone know how to get desktop sharing working on Phosh? Currently, I'm using Manjaro but I could easily switch to another distro if it's easier to get it working.
Specifically, I want to create a new session with a full desktop, not share the phone screen.
You can try wayvnc, I made it work on Android, with Alpine and Phos
Install wayvnc on the PPP then:
export XDG_RUNTIME_DIR=/tmp
export WLR_BACKENDS=headless
phoc -E '/usr/libexec/phosh -U' &
wayvnc
After this you should connect from another device using a vnc viewer to your PPP
This is more o less how I did it on Android I'm not sure if something should be different on your case.
(09-03-2022, 04:14 AM)uzanto Wrote: You can try wayvnc, I made it work on Android, with Alpine and Phos
wayvnc
Thanks, I'll give it a try.
The wayvnc instructions are pretty thin. Is it possible to setup a second screen that's more desktop oriented (landscape, 1x scale) instead of repeating the phone display?
(09-05-2022, 02:39 PM)Barugon Wrote: The wayvnc instructions are pretty thin. Is it possible to setup a second screen that's more desktop oriented (landscape, 1x scale) instead of repeating the phone display?
Not sure, in /etc/phosh/phoc.ini you can chande headless mide resolution, give it a go and see what happens.
(09-06-2022, 06:29 AM)uzanto Wrote: Not sure, in /etc/phosh/phoc.ini you can chande headless mide resolution, give it a go and see what happens.
The best I could accomplish was a black screen.
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 6,168 06-30-2025, 10:51 AM
Last Post: Dendrocalamus64
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 0 2,047 06-09-2023, 12:55 PM
Last Post: ArchiMark
  Online Accounts (Phosh) Barugon 1 3,104 11-10-2022, 11:24 PM
Last Post: Barugon
Lightbulb Manjaro Phosh vs. Manjaro Plasma on Pinephone Pro? danimations 10 18,328 07-15-2022, 10:10 AM
Last Post: Fred Zyphal
  [Arch Phosh] Asian characters not displaying bobjrsenior 0 2,348 06-08-2022, 12:18 PM
Last Post: bobjrsenior
  PPP (Manjaro/Phosh) lags when speaker above 50% wilsonjholmes 2 5,168 04-27-2022, 10:11 AM
Last Post: wilsonjholmes
  Arch linux phosh - no cellular with T-Mobile sim Conjada 14 18,714 02-21-2022, 10:11 PM
Last Post: The3DmaN
  Dev Addition - Manjaro/Phosh - Apps not activating iwm 5 8,850 02-08-2022, 01:11 PM
Last Post: iwm
