Megapixels doesn't work
When I run megapixels in the terminal I get the error: ''usr/share/megapixels/config/pine64,pinephone-pro-ini not found. Could not find any config file." How can I solve this problem?
A bit different in mobian - since yesterday's update, it works but touching any button makes it exit without doing anything. Worked before the update.
Is there any way to install megi's camera app?
(08-21-2022, 08:18 AM)Glenn Wrote: ...
I have same prob on arch - need to wait for an update with a suitable ini (or clone one from elsewhere).
(08-21-2022, 08:34 AM)Eugo Wrote: ...
git clone https://megous.com/git/ppp-cam
Should add it doesn't work for me though either at the moment - ERROR: Unexpected number of planes: 0 all the time
I think there's some difference between PP and PPP, and I have a PP. Well, can't have everything.
There are some major differences camera wise between the PP and PPP. Namely, the back camera of the PP is the front camera of the PPP, with different cameras otherwise.
  Alarm clock doesn’t work Captain1ndustry 14 30,713 12-23-2025, 12:12 AM
  pinephonepro.ini for Megapixels biketool 1 3,379 01-04-2025, 04:26 PM
  The program doesn`t detect the camera blag0rag 6 7,085 09-17-2024, 03:45 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 7,892 09-05-2023, 11:16 AM
Last Post: nickolas
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 4,072 08-30-2023, 03:59 AM
Last Post: karensather
  Chatty does not work after suspend mode user641 4 7,299 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 4,975 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 16,998 02-26-2023, 11:47 PM
Last Post: SukiiPooru
Exclamation The webcam doesn't work in Firefox anonymous 0 2,423 11-06-2022, 01:45 PM
Last Post: anonymous
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 3,453 08-06-2022, 01:10 AM
Last Post: elode
