firmware udate Quectel EG25-G modem
in https://gnulinux.ch/postmarketos-v22-06-veroeffentlicht
wrote Lioh Möller about the possibility of updating the firmware of the modem Quectel EG25-G.
I followed the instructions. There were no error messages. It now has the latest firmware version.
However, the modem does not work under postmarketOS. Only in Manjaro Phosh Beta 24 does it work if I toggle the "Mobile Data" switch on and off and on again under "Network".
The modem also does not work with Manjaro-ARM-plasma-mobile-dev-pinephone-20220613.
It's like an own goal.
did you flash stock rom https://github.com/Biktorgj/quectel_eg25_recovery or half-opensource https://github.com/Biktorgj/pinephone_modem_sdk ?
i still recommend re-initializing some settings even if modem says they are set. like volte:
AT+QCFG="ims",1
AT+CFUN=1,1
in extreme situation use following, i don't think this works on "pinephone modem sdk" firmware.
!!warning!! only use these if modem chip is seriously messed up!
needs to be used as bundle
AT+QPRTPARA=3    << Factory reset NVM items (careful, you may lose modem control!)
AT+QPRTPARA=1    << Save NVM items
!!warning!!
Unfortunately, I can't answer your question because I worked exactly according to the instructions, just like in a cookbook:
https://wiki.postmarketos.org/wiki/Fwupd
My expertise would have to be a level higher to carry out your advice. It also has a bit to do with my age.
If you could translate your advice into some sort of building guide, it would certainly help me.
Many Thanks!
Try following this guide, and install the FOSS firmware of biktorgj
(06-18-2022, 01:32 AM)user641 Wrote: Try following this guide, and install the FOSS firmware of biktorgj
this one?
it looks interesting and I do not love having random stockish androind running on my modem but not all functions are implimented yet.
this one?
yes, exactly
this one?
yes, exactly
In your testing are there any missing functions with this firmware?  GPS, SMS, phonecalls, data?
this one?
yes, exactly
only some troubles with calls, but there's a fix: https://github.com/Biktorgj/pinephone_mo...ETTINGS.md
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 18,201 12-12-2025, 03:27 AM
  Modem Issues with the Pinephone Temmie19 5 5,040 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 4,711 02-05-2025, 02:30 AM
  Supported Carrier and Modem Bands NachoMomma 4 7,454 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,640 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,333 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 8,098 02-15-2023, 11:17 AM
Last Post: fxc
  Need command to tell what modem firmware I am on. purpletiger 4 7,256 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 10,654 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 10,186 05-31-2022, 06:41 PM
Last Post: SwordfishII
