error updating arch pohosh
i am trying to update archlinux dreemurrs 20220124 from distro demo image 2021-11-20 and i get error
ERROR: alsa-ucm-pinephone: signature from "DanctNIX Build system <builder@main-key.danctnix/org>" is unknown trust  File /var/cache/pacman/pkg/alsa-ucm-pinephone-0.6.1-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)) do you want to delete it?
 i tryed some suggestions to refresh the keys but i get the same error
 ezik
Maybe you need to run `pacman-key --populate danctnix`?
We had people coming up and tell us about this error, but so far I still haven't figured out what happened (maybe the key database got corrupted?).
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
(07-15-2022, 02:15 PM)Danct12 Wrote: Maybe you need to run `pacman-key --populate danctnix`?
i decided to flash original archlinux (not multiboot) and no problem with it
if i'll try multiboot again i'll check it
ezik
ezik
 yes you are right   thanks
ezik
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,145 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,118 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone error system-generators/ostree-system-generator failed with exit status 127 Daniello 3 4,088 06-15-2024, 03:38 AM
  Updating Arch Linux _radv_ 8 9,531 02-20-2024, 09:35 AM
Last Post: _radv_
  error loading libsodium.so.26 for flatpak _radv_ 4 6,068 02-02-2024, 04:26 PM
Last Post: _radv_
  How to install arch with FDE user641 3 5,876 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 9,030 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,350 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 3,949 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,330 12-03-2022, 08:35 PM
Last Post: Chief
