Won't boot, black screen
Today my pinephone stopped booting: green led, black screen.
It allready happened to me once, it was after an upgrade that went bad (phone going to sleep before finishing building initrd, me not noticing, something like that), it was quick to resolve by mounting the phone on my laptop via USB, and chrooting in it.
But today it's harder, I tried multiple things with no luck:
- In a chroot ran: dpkg-reconfigure linux-image-5.15-sunxi64
- Configured an older kernel, and tried setting a rescue mode in /boot/extlinux/extlinux.conf directly, and noticing the comment, by modifying the files in /etc and running u-boot-update too.
- Dropped `splash` and added `console=tty1` in `/etc/u-boot-menu.d/pinephone.conf`, ran `u-boot-update`. (Still black screen at this point).
- Soldered a jack-to-USB using an old "FTDI Friend" round in a drawer so I can take a look at serial output (it works!)
At this point I noticed:
> Moving Image from 0x40080000 to 0x40200000, end=415b0000
>   Loading Ramdisk to 452ba000, end 49fff776 ... OK
> FDT and ATAGS support not compiled in
> resetting ...
and after doodling around decided to remember that u-boot was no longer supported in Mobian.
So I installed tow-boot (wow it's nice not having to change the SD card each time I want to switch to mass storage ♥).
But still no luck, here's what I see over serial:
Tow-Boot 2021.10 (Oct 04 2021 - 15:09:26 +0000)004 [variant: mmcboot]
CPU:  Allwinner A64 (SUN50I)
Model: Pine64 PinePhone (1.2)
DRAM:  3 GiB
MMC:  mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from nowhere... OK
In:    serial
Out:  serial
Err:  serial
Net:  No ethernet found.
Please press [ESCAPE] or [CTRL+C] to enter the boot menu.
off
off
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
995 bytes read in 2 ms (485.4 KiB/s)
U-Boot menu
1:      Debian GNU/Linux bookworm/sid 5.15-sunxi64
2:      Debian GNU/Linux bookworm/sid 5.15-sunxi64 (rescue target)
3:      Debian GNU/Linux bookworm/sid 5.10-sunxi64
4:      Debian GNU/Linux bookworm/sid 5.10-sunxi64 (rescue target)
Enter choice: 1:        Debian GNU/Linux bookworm/sid 5.15-sunxi64
Retrieving file: /initrd.img-5.15-sunxi64
81025327 bytes read in 1739 ms (44.4 MiB/s)
Retrieving file: /vmlinuz-5.15-sunxi64
7448010 bytes read in 160 ms (44.4 MiB/s)
append: root=/dev/mapper/calamares_crypt ro
  Uncompressing Kernel Image
  Loading Ramdisk to 452ba000, end 49fff92f ... OK
Starting kernel ...
then nothing on the screen, nothing on serial, and it's time for me to go to sleep.
Any idea?
I read your post carefully and if I'm reading it right it seems to me like you have done most things possible. Might it be better at this point to simply re-flash the eMMC card with a new Mobian? I should also suggest Arch Linux Phosh as well.
In one hand it looks like a good idea (to fix the issue), in the other and I prefer understanding things so I'll postpone this idea as long as possible Smile
Solved my issue. Since yesterday I was wondering how u-boot passed arguments to the kernel, as I was not seeing them in extlinux.conf, it looked like:
label l0
    menu label Debian GNU/Linux bookworm/sid 5.15-sunxi64
    linux /vmlinuz-5.15-sunxi64
    initrd /initrd.img-5.15-sunxi64
    append root=/dev/mapper/calamares_crypt ro quiet
I was like "OK 'append' but where are the others"?
Doodling around the u-boot documentation and things, I spotted:
root@seraph:/# apt-cache policy u-boot-menu
u-boot-menu:
  Installed: 4.1.0
  Candidate: 4.1.0
  Version table:
*** 4.1.0 990
        990 http://deb.debian.org/debian bookworm/main arm64 Packages
        100 /var/lib/dpkg/status
    4.0.4mobian1 990
        990 http://repo.mobian-project.org bookworm/main arm64 Packages
So I promptly ran:
apt install u-boot-menu=4.0.4mobian1
u-boot-update
Rebooted, and boom, solved.
In case someone needs to do it too, I'm doing it over USB mass storage, (hold volume up in tow-boot until the 2nd vibration, or via Jump Drive), I installed
apt install qemu-user-static binfmt-support
So I can run binaries via qemu, and then just run:
mount --bind /dev /media/mdk/root/dev/
mount --bind /sys /media/mdk/root/sys/
mount --bind /proc /media/mdk/root/proc/
mount --bind /media/mdk/boot /media/mdk/root/boot/
chroot /media/mdk/root/
to chroot myself in my phone.
So, let's go read /var/log/apt/history.log:
Start-Date: 2022-06-25  08:23:26
Commandline: apt full-upgrade
Requested-By: mobian (1000)
Upgrade: gstreamer1.0-plugins-ugly:arm64 (1.20.2-1+b1, 1.20.3-1), gsasl-common:arm64 (1.11.3-3, 2.0.0-1), libinput10:arm64 (1.20.1-1, 1.21.0-1), u-boot-menu:arm64 (4.0.4mobian1, 4.1.0), libgsasl18:arm64 (1.11.3-
3, 2.0.0-1), libgstreamer-plugins-bad1.0-0:arm64 (1.20.2-1+b1, 1.20.3-1), gir1.2-gst-plugins-bad-1.0:arm64 (1.20.2-1+b1, 1.20.3-1), libgnutls30:arm64 (3.7.4-2, 3.7.6-2), gstreamer1.0-plugins-bad:arm64 (1.20.2-1+
b1, 1.20.3-1), libgnutls-dane0:arm64 (3.7.4-2, 3.7.6-2), libinput-bin:arm64 (1.20.1-1, 1.21.0-1)
End-Date: 2022-06-25  08:25:38
and here we are, u-boot-menu upgraded from 4.0.4 (mobian side) to 4.1.0 (debian side).
(07-03-2022, 03:09 AM)mdk Wrote: Solved my issue. Since yesterday I was wondering how u-boot passed arguments to the kernel, as I was not seeing them in extlinux.conf, it looked like:
label l0
u-boot-menu:
  Installed: 4.1.0
  Candidate: 4.1.0
  Version table:
*** 4.1.0 990
    4.0.4mobian1 990
So I promptly ran:
u-boot-update
Congrats on solving it. This is a good thread to keep around as someone else might find this useful. Just the other day I flashed Tow-boot to boot sector  on my PP and this is great. No more jump drive although jump drive was like a must have in the beginning.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,076 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,053 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 10,504 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,952 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,190 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,284 01-15-2025, 08:08 PM
  boot gets stuck shortly after disk decryption vortex 9 11,871 09-11-2024, 05:40 AM
Last Post: normangraves
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,039 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,357 12-26-2023, 06:08 AM
Last Post: mdk
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 10,428 11-22-2023, 11:46 AM
Last Post: aLoop100o
