3.5mm jack audio quality?
Hi folks,
How is the audio quality that you get via the 3.5mm jack?
Thanks.
For which device are you asking? Pine builds several products with a 3.5mm audio jack, AFAIK.
Edit: Moved the thread in the right section.
(06-16-2022, 04:15 PM)fxc Wrote: For which device are you asking? Pine builds several products with a 3.5mm audio jack, AFAIK.
Ooops sorry. Pinephone and Pinephone Pro. I'm wondering the about quality of those. Also, if there is a DAC or amplifier.
Pinephone uses the built in headphone output of the A64 via a BCT4717 analog switch chip between it and the headphone socket to switch it between headphone and serial port use. The closest I've seen to measurements is this thread, which started with some measurement errors, and lacked sufficient detail of things like mixer settings to be sure the final result was representative.
https://forum.pine64.org/showthread.php?tid=11625
I haven't checked the Pinephone Pro schematics, but you'll find the link in the wiki.
  How to play audio from ffmpeg? Manieck71 10 14,528 08-31-2023, 03:02 AM
Last Post: Manieck71
  Modem audio settings jack1 2 4,123 02-04-2023, 04:01 PM
Last Post: jack1
  scratchy phone audio KABA 3 6,368 06-24-2021, 01:15 PM
Last Post: jameslauren11
  poor call quality try flipping switch six D4rkh0rs3 0 2,715 05-12-2021, 12:09 PM
Last Post: D4rkh0rs3
  Audio quality GloriousCoffee 5 12,531 10-24-2020, 12:00 PM
Last Post: GloriousCoffee
  Phone Calling - Extremely Bad Quality mischmerz 5 10,298 09-21-2020, 04:37 AM
Last Post: SwordfishII
