no emmc after flash
sorry if this has been covered already. been using manjaro phosh feb release no issues til
today while trying to place a call it hung and then I could no longer open the calls app, place
or receive calls. I successfully flashed using jumpdrive but after it wont boot. if i place the
jumpdrive sd back in the phone i can see the jumpdrive splash on the phone but the emmc
is not visable any longer on my laptop. any ideas?
(05-19-2022, 07:04 PM)ragele Wrote: sorry if this has been covered already. been using manjaro phosh feb release no issues til
That would typically happen with a fully drained battery. In that case other OSes (except for Jumpdrive) won't boot either.
I would recommend to let the phone charge in Jumpdrive for a couple of hours. If the phone doesn't work properly after a reboot I would suggest trying to boot a different operating system from the microSD card and to then flash the eMMC from that OS.
traced the problem back to a bad mobian image I had downloaded mixed with the problem of
going back and forth between mobian and manjaro without wiping emmc before flashing...
(05-29-2022, 08:03 PM)ragele Wrote: traced the problem back to a bad mobian image I had downloaded mixed with the problem of
Mind that Mobian comes without a bootloader now and requires Tow-Boot to be flashed manually.
  install iso from sd card to emmc aular 2 4,165 03-11-2024, 10:24 PM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 6,755 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 7,424 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 5,919 04-13-2023, 05:55 AM
  This is how you flash to eMMC easily Luke 49 157,113 12-25-2022, 05:13 PM
Last Post: fxc
  emmc formatted by mistake (it no longer appears) elode 5 8,767 07-12-2022, 04:33 AM
Last Post: elode
  Tow Boot - How to Flash a New OS? arkadione 3 6,961 06-15-2022, 04:10 PM
Last Post: kmsgli
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 4,100 05-31-2022, 04:26 PM
Last Post: fxc
  eMMC label gilwood 1 4,754 12-31-2021, 06:25 PM
Last Post: moonwalkers
  Cannot Create Profile - Cannot even Flash OS absolutenoob 6 11,607 12-17-2021, 03:52 AM
Last Post: guenther
