Danger icon on mobile network
Hi there everyone,
I'm running Phosh Manjaro ARM and I have a persistent orange danger sign in my mobile network. The icon has 4 vertical bars of increasing height. The tallest one is grey and the others are white. Then there is an orange square on the foreground with a black exclamation mark inside.
What does this mean and how should I fix this?
Thanks a lot to this beautiful community!
That means there is no mobile Internet connection. Your embedded image is not working for some reason.
(05-01-2022, 03:39 PM)fxc Wrote: That means there is no mobile Internet connection. Your embedded image is not working for some reason.
I still can't upload the image properly. Anyway I can receive and send calls and texts. I can also use mobile data.
Might this be a bug? Who and where should I report this?
does this forum software even support embedded images? i have put images on external server on links to it.
I opened an issue for this at Manjaro's Git Lab: https://gitlab.manjaro.org/manjaro-arm/i...issues/257
can it be because the sim is secondery (for a car)?
ezik
I still have this issue as well using Arch Linux Phosh. The device was working perfectly and then suddenly no text could be sent. An orange exclamation mark appears periodically and when this is present I can send text - but I can always receive text. Also when this exclamation mark appears I have no access to my Evolution email through sim card or Falkon web browser. When I reboot the device and get a normal 2 to 3 bars signal strength I can still receive text but cant send text. Phone calls work fine either way. Internet access also returns properly. I suspect strongly this is due to a Gnome-Calls update back in March-April. It's not a bad situation for me as it is more important to receive text than send and I always want Evolution email and Falkon browser access.
Edit: May 18,2022
I have noted that by enabling or disabling mobile data will have different effects for different functions.
Disabling mobile data allows me to send text and the exclamation mark appears in banner over sim card strength (but I can always receive text regardless)
Enabling mobile data terminates my ability to send text and exclamation mark disappears (but can always receive).
With mobile data enable I can also access internet data through sim card.
It seems to defy logic but thought I would share this observation with the community.
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,586 03-02-2023, 07:25 PM
  Remove Grayed-Out Alarm Icon from Panel? jakfish 2 4,423 03-02-2023, 09:49 AM
Last Post: jakfish
  gnome-mobile dev Uturn 1 3,398 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 17,159 01-25-2023, 04:15 PM
  Disabling screen timeout for plasma mobile rp3 7 16,519 09-05-2022, 03:50 PM
Last Post: christev1
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 54,769 07-28-2022, 12:40 PM
Last Post: johaennessen
  Waydroid network connection Uturn 3 6,662 07-03-2022, 11:10 AM
Last Post: RudderDuck
  double tap to wake > plasma mobile Uturn 3 5,733 05-19-2022, 07:55 PM
Last Post: epiii2
  auto start waydroid in plasma mobile? Uturn 2 6,268 04-19-2022, 03:47 AM
Last Post: dorthatapia
  Some "tricks and tips" for Manjaro Plasma Mobile acrux 1 6,403 03-10-2022, 10:38 AM
Last Post: israel
