Access Volume Button via bash
Can someone please tell how I can read the state of the volume buttons (PinePhonePro) via bash ?
read KEY_VOLUMEDOWN read KEY_VOLUMEUP
**sidenote:**
want to create a supersimple screenshooter for Phosh, it will help a lot in writing docs...
What I found https://xnux.eu/devices/feature/volumekeys.html
On the PPP, there are following devices:
/dev/input/event0: gpio-vibrator /dev/input/event1: adc-keys /dev/input/event2: Goodix Capacitive TouchScreen /dev/input/event3: gpio-key-power /dev/input/event4: gpio-key-ri /dev/input/event5: PinePhonePro Headphones
So I am able to read if the Volume_Key is pressed (from adc-keys) with:
libinput debug-events --device=/dev/input/event1
Which gives me some debug outputs of the pressed hardware keys without debouncing:
event1  DEVICE_ADDED            adc-keys                          seat0 default group1  cap:k event1  KEYBOARD_KEY            +0.000s KEY_VOLUMEDOWN (114) pressed event1  KEYBOARD_KEY            +0.208s KEY_VOLUMEDOWN (114) released event1  KEYBOARD_KEY            +2.196s KEY_VOLUMEUP (115) pressed event1  KEYBOARD_KEY            +2.404s KEY_VOLUMEUP (115) released
The idea is to read this keys with something simple like: read or showkey to be able to make a simple if volume up and down statement to trigger screenshooter
but I do not get input from the volume keys with this methods...
I know that SXMO are using volume keys extensively in their UIs (which are shell and dmenu based). I bet you could find something if you dig around over there a bit. If you can't find it, maybe ask in their IRC or mailing list.
Cheers,
TRS-80
Protocols, not Platforms
(04-30-2022, 08:28 PM)TRS-80 Wrote: I know that SXMO are using volume keys extensively in their UIs (which are shell and dmenu based).  I bet you could find something if you dig around over there a bit.  If you can't find it, maybe ask in their IRC or mailing list.
Thanks for the hint, could not find it so far there, but I'll keep on digging...
OK, I was just chatting with guys in #sxmo and they are basically using setting dwm to call sxmo_hook_inputhandler.sh upon button press.
I don't know what window manager you are using, but setting something in there is probably the easiest way.  As opposed to what you are trying to do is a bit more low level.
Cheers,
TRS-80
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,191 07-01-2026, 10:53 AM
Last Post: FR_IV
  How to access the hardware privacy switches? Pinoideae 3 5,764 02-09-2022, 10:45 PM
Last Post: bcnaz
