I'd like to have a Discord client on Mobian
I see that there isn't a Discord client under the Software installer nor available at the command line with apt.
Would it be possible to install the .deb directly?
If the source code needs to be ported to Mobian, are there guides for how to go about that? I'm willing to give it a try.
Thank you.
Discord is closed source, so you either need to use the browser version (which would be better anyway, since the Discord app is a massive spyware), or kiss their feet in return to make an ARM version available (and I doubt they will).
If you go for the browser version, I suggest you use Qutebrowser for that, since most other browsers are pretty much soyware, and Discord itself is very bloated too.
And Qutebrowser allows you to zoom the web app down while still being able to click everywhere without having to misclick all the time (using the "F" key).
Zooming out is necessary, because otherwise you won't see shit while using Discord on a small screen, since the desktop/web version of Discord is not a responsive app.
母語は日本語ですが、英語も喋れます(ry
Ugh, Discord siphons all kinds of data... May as well just use a Google device and skip the Linux
(04-16-2022, 06:55 AM)Hobbes42 Wrote: Ugh, Discord siphons all kinds of data... May as well just use a Google device and skip the Linux
Yeah, I don't get it, either.
*cough*pointsatsignature*cough*
Cheers,
TRS-80
Protocols, not Platforms
  Printing from Mobian johnd 3 5,134 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,098 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,117 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,848 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,350 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,624 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,690 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,304 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,571 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,307 05-06-2025, 02:19 AM
