Modem in failed state, not sending/receiving SMS
I have a PP Braveheart on Arch Phosh that had worked fine for almost 2 years on Verizon's CDMA network. Calls, SMS, and now even MMS worked. Occasionally the inbound SMS would get hung up, but clearing the modem cache by connecting to the modem and running
AT+CMGD=0,4
resolved that. Recently I wrote a systemd service/timer that ran
echo "AT+CMGD=0,4" > /dev/ttyUSB2
every hour. Seems my issues have arisen since then. Now when I try to manually clear the cache it just returns
AT+CMGD=0,4AT+CMGD=0,4 AT+CMGD=0,4AT+CMGD=0,4 AT+CMGD=0,4AT+CMGD=0,4 AT+CMGD=0,4AT+CMGD=0,4 AT+CMGD=0,4AT+CMGD=0,4 AT+CMGD=0,4AT+CMGD=0,4
repeatedly in minicom. I tried flashing biktorgj modem firmware to "refresh" my modem, but it gets hung at
Sending AT+QFASTBOOT... < waiting for any device >
and detects no fastboot devices.
lsusb
returns
Bus 002 Device 002: ID 2c7c:0125 Quectel Wireless Solutions Co., Ltd. EC25 LTE modem
So the modem is there, just not responding to me in the way I have become familiar with.
It seems maybe the modem may be the source of these SMS issues, but I'm not sure how to resolve it if its not responseive to minicom, atinout, or fastboot. Any thoughts?
also
sudo mmcli -m any -e
returns
error: couldn't enable the modem: 'GDBus.Error:org.freedesktop.ModemManager1.Error.Core.WrongState: modem in failed state'
I have tried restarting eg25-manager and rebooting. How might I get out of this failed state?
Pretty much out of my depth, but pull the battery for 3 mins to make sure the modem gets a fresh start is my only suggestion.
Happened to me once my modem went into bizarre mode and mine did recover.
tried pulling the battery, still booted back up in failed state
Temporarily boot to another distro, like pmOS or Manjaro, from SDCard. See if something became messed up during an upgrade.
If that ^ doesn't work, poke around on the issue trackers for something similar. IIRC, people have "lost" their modems before and sometimes recovered them. I've found the eg25-manager and modemmanager boards to be full of helpful details.
https://gitlab.com/mobian1/devices/eg25-manager
https://gitlab.freedesktop.org/mobile-br...demManager
PPv1.2a running PMOS ... almost a daily driver!
Same response in Mobian booted from sdcard. I think the issues is on the modem side. Any suggestions?
If all else fails you can look into opening the phone and jumpering pins / test points to boot the modem into EDL mode then reflashing with Qfirehose.
https://wiki.pine64.org/wiki/PineModems
https://github.com/Biktorgj/quectel_eg25_recovery
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,200 09-11-2026, 09:18 AM
Last Post: idice
  Modem Issues with the Pinephone Temmie19 5 7,354 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,112 02-05-2025, 02:30 AM
  Supported Carrier and Modem Bands NachoMomma 4 9,449 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,459 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,716 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 9,425 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 16,188 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,630 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 12,499 06-13-2022, 04:12 AM
Last Post: zetabeta
