PPP microphone not working for calls, is this normal?
So I have not been able to use the microphone for calls on any distro of Linux on my dev edition PPP, so I installed the android test image to try to see if it work there. It did not work in the android test image either. Is this normal?
I ask because I have read various people saying calls worked for them on reddit or on this forum. Mic is not working at all for me, just trying to figure out if I need to replace my PPP or if this is just the current state of the device.
Same issue here. I think it's just the state of the phone calls app.
Using Arch Plasma, the mic doesn't work at all for calls. However, I decided to download a voice recording app, and the mic worked for that.
Using Arch Phosh, the mic sorta worked for calls; the person on the other end could hear something, just nothing they could make out.
(03-24-2022, 06:42 PM)Dinobot Wrote: Same issue here. I think it's just the state of the phone calls app.
Thanks for the reply. I am glad to know its not a issue with my particular unit.
Mine works perfectly on Arch Linux ARM (Danctnix), the only real customization I've done is switching to linux-megi-rc kernel. I actually took calls for several hours yesterday, and a non-functioning microphone would have been a problem.
With the record app, I found that the input must be adjusted away from default to alsa. And there is a volume control for the microphone in settings which must be increased for the different modes.
  Pinephone Pro Earpiece is not working, need help silverwing 2 4,226 03-25-2023, 11:46 AM
Last Post: UltraBlack_
  manjaro-phosh did make calls -- now nothing tckosvic 6 10,079 03-07-2022, 02:38 PM
Last Post: tckosvic
  Microphone Emilio 1 3,416 03-06-2022, 02:06 PM
Last Post: mburns
  PPP did make calls -- now will not tckosvic 1 3,678 03-01-2022, 10:08 PM
Last Post: tckosvic
