No connection to internet without wifi :/
Question
Hello  Smile
I received my pinephone pro in February 2022.
I installed postmarket os and it works pretty well, except for one thing:
I can't connect to the internet without wifi. In other words, as soon as I leave my house, I no longer have access to the Internet.
I looked in the settings and there, I checked "Mobile Data" and "Data Roaming".
In the advanced settings > Access Point Names, I chose the one that seems to me to be the one that corresponds to my provider… nothing helps.
Any ideas?
Thanks Rolleyes
(03-13-2022, 08:49 AM)elode Wrote: Hello  Smile
Any ideas?
Thanks Rolleyes
  You need to add (+) your carriers exact APN information,  it should be available from your carriers website.
as an example for Pure Talk :
APN :  RESELLER
This needs to be added,  NOT by editing an existing APN as it will just return to its original state with each reboot.
Entering the APN as above will allow you to connect to data,  but you will need to add more info for mms text.
This varies per Distro and per carrier.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I haven't checked for mms yet, but for internet it works.
Thank you very much for your directions Tongue
I think some of the operating systems are very close to making mms work "out of the box"
*** (It does work now on some operating systems with a little tweaking)
For now just the first 2 lines are needed for cellular data to work.
We will need to add a little more info in settings (Access Point Names) when we finally do use the mms.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,137 11-18-2024, 02:23 AM
Last Post: linmob
  No automatic hub connection on reboot. --- 0 2,427 02-06-2022, 06:52 PM
Last Post: ---
  No USB connection - phone not seen! --- 24 44,972 12-14-2020, 08:24 PM
Last Post: ---
  Wifi and bluetooth disabled after upgrading to PMOS kernel 5.9.1 aithal 0 3,575 11-09-2020, 01:17 AM
Last Post: aithal
  Wifi not working dbrandon 9 18,058 10-09-2020, 06:37 AM
Last Post: quininer
Question WiFi looks to be working, but ... vidarr 2 5,624 09-08-2020, 04:21 PM
Last Post: vidarr
  Is it possible to pre-configure wifi and ssh with pmbootstrap? kelbot 2 8,760 07-06-2020, 01:55 AM
Last Post: ChriChri
