U-Boot, partition layout and flash
Hi. I compiled Android sdk from wiki without errors, but now i dont know how flash the files to sdcard (boot.img, system.img. recovery.img)
And i compile U-Boot from longsleep, this is compatible with Android?
What is the partition layout for Android? I try this http://linux-sunxi.org/Boot_Android_from..._Partition
Welcome to the club, follow here http://forum.pine64.org/showthread.php?tid=1116
No information anywhere Sad
My USB to TTL arrived today, i think it helped me a little. I try again laterBig Grin
(05-29-2016, 10:42 PM)kap1r0t0 Wrote: And i compile U-Boot from longsleep, this is compatible with Android?
Not compatible with Android (modified boota)
if i compile u-boot from mainline is compatible?
No it is not.
Could you give me some information on how to boot android ?
I have no idea or care about Android. That's why I do Linux :-)
(05-29-2016, 10:42 PM)kap1r0t0 Wrote: Hi. I compiled Android sdk from wiki without errors, but now i dont know how flash the files to sdcard (boot.img, system.img. recovery.img)
If you just would like to test these images, you don't have to create PhoenixCard image.
You can flash an offical image with PhoenixCard to create partitions on your SD Card.
After that you can use dd to write images.
System is in 7th partition and boot is in 6th partition.
hahaburger,
Thank you for your response. But I think that kap1r0t0 needs more help than that - I have spoken to him over the recent days and he is unsure about how to effectively create an image from the parts he compiled (boot.img, system.img. recovery.img). He is looking to find out the process of taking these and making them into a bootable image. Help would be appreciated Smile
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 5,089 01-15-2018, 11:05 PM
  Kickstarter edition wont boot to android bilbo6209 1 5,020 01-09-2018, 08:03 PM
  Boot hangs on pine64, how to debug? olh 1 5,209 08-29-2017, 12:04 AM
  Pine64+ 1G: boot loader details required Tanveer 4 10,103 07-29-2017, 09:07 PM
Last Post: Tanveer
  Pine 2GB won't boot Android anymore Bluphire 5 11,200 05-29-2017, 09:34 PM
Last Post: dkryder
  Custom boot animations Bluphire 4 8,522 05-05-2017, 02:00 AM
Last Post: Quezbeme
  Change Android boot logo? ipsw 5 15,584 05-03-2017, 09:39 PM
Last Post: Quezbeme
  Do apps run in the background at boot up? Penfold 3 6,981 03-10-2017, 02:19 PM
Last Post: mporeh
  Partition Table xalius 1 4,396 07-24-2016, 05:08 AM
Last Post: xalius
  Boot up issue... shadow22 9 14,188 06-23-2016, 07:44 AM
Last Post: shadow22
