How to charge with 3 ampere / 5 volt / 15 watts?
in the pine phone manual that came with the phone it says the phone can be charged with up to 3 ampere.
I bought a 3 ampere phone charger but the 'Power supply' tool says this about the usb charger:
'Current Limit: 1.5A'
Can I do something about this?
The phone is charging just as slow as with my old 1.5A charger, so as of now I just wasted my money on the new charger Sad
(03-09-2022, 09:27 AM)lacriz Wrote: Hi,
Where are you reading the amps/power supply tool? (I am using mobian and this is not in settings)
I use a pine-power and am curious myself.
(03-10-2022, 03:48 AM)biketool Wrote: Where are you reading the amps/power supply tool? (I am using mobian and this is not in settings)
According to https://packages.mobian-project.org/ it should be possible to install this tool on Mobian:
sudo apt get powersupply (or similar)
So I am showing 3 amp(voltage is blank) from a portable pine-power, but the battery charging shows only 5.13w when I am at 66% battery.
  Pinephone refusing to charge while suspended tiol 1 6,086 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,233 02-17-2024, 04:15 PM
Last Post: vortex
  PinePhone constantly vibrating and won't take charge ImmyChan 5 10,122 07-23-2023, 03:49 PM
Last Post: kb-zealot
  Mainboard replacement does not boot/charge boarf 2 5,448 05-02-2021, 10:47 AM
Last Post: boarf
  Battery won't charge. Liveandkicking 18 29,313 01-27-2021, 11:02 AM
Last Post: Twig
  PinePhone Battery won't charge past 89% mfd141 3 7,251 12-28-2020, 10:43 AM
Last Post: mfd141
Question How do I charge my PinePhone safely? thatrandomguy 15 30,978 10-08-2020, 08:19 AM
Last Post: wibble
  What's the trick to get the battery to charge? diodelass 2 6,410 06-05-2020, 09:38 AM
Last Post: diodelass
