Bluetooth audio support?
Has anyone had any success getting bluetooth audio to work in Mobian? I have a couple of Samsung HM1350 headsets that I used to use with my old flip phone. When I connect either one to the Pinephone instead of audio the headset just emits a loud buzzing. For now if I need to use a headset I used a wired one but that's a bit of a pain, and at least for outgoing calls it needs to be plugged in after the call is in progress or the microphone will not work.
Are there any bluetooth headsets that are known to work yet?
(02-16-2022, 02:48 PM)Zebulon Walton Wrote: Are there any bluetooth headsets that are known to work yet?
I tried a bluetooth speaker (Bose) a while ago and it just worked. No experience with headphones though.
I regularly use a pair of JBL BT450 headphones as well as two external BT speakers (one JBL Flip 4 and a cheap supermarket thingy) -- no problems at all. I have never tried to use the mic of the headphones though, but audio is no problem at all.
Working fine with a sony and bose speakers via bt here
N.B. the difference between various Bluetooth device profiles; in particular, 'playing music' and 'headset profile' (i.e., using phone) are two wholly different things!
For the latter, see: https://gitlab.com/mobian1/issues/-/issues/160
Cheers,
TRS-80
Protocols, not Platforms
(02-27-2022, 10:48 PM)TRS-80 Wrote: N.B. the difference between various Bluetooth device profiles; in particular, 'playing music' and 'headset profile' (i.e., using phone) are two wholly different things!
I figured as much, I know this topic has come up before and I was wondering of there has been any progress. It's not a deal breaker for me but it's inconvenient to have to use a wired headset. Even the wired headset doesn't work quite seamlessly. At least for outgoing calls you have to plug it in while the call is in progress. If you just plug it in and make the call the microphone doesn't work.
  Mobian, Suspend, and Audio Playback biketool 0 2,951 12-11-2024, 12:56 AM
  Could not initialize OpenGL support jojuma 6 11,449 09-14-2024, 12:06 PM
  Audio output switching anomalies treebeard 1 3,359 06-10-2024, 06:37 AM
Last Post: anonymous
  Bluetooth audio revisited 3x5co 1 3,635 01-10-2023, 05:51 PM
  No audio on calls after updating today Zebulon Walton 10 16,043 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  Ringtones and Audio Modes biketool 0 2,411 09-05-2022, 10:42 AM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,853 07-17-2022, 10:34 AM
Last Post: 3x5co
  Any fix for bluetooth crash when entering pairing password? kk22 0 2,987 06-18-2022, 07:51 PM
Last Post: kk22
  Blueman GUI Bluetooth Network Access Point - fixing Bridging biketool 12 25,775 05-26-2022, 05:56 AM
  Scripting Bluetooth Hotspot for Mobian biketool 1 3,937 03-20-2022, 03:03 PM
