Glacially slow system updates on Mobian - waiting on boot 20m - 1h
Hello!
I have Mobian installed to the embedded SD in my PinePhone PmOS edition.
Any time I do a System Update with a reboot, it takes very long. I haven't timed it, but I wager the better part of an hour was spent updating once, then when I loaded in it asked for another (it's been a while, so that's fine), but then that took ~20m.
What are the average system update times for anyone else here?
Is there a way to speed this up? Is it affected by system encryption?
Hello there,
the cause of lenghty updates might be the update of initramfs, which takes quite a while in my case with full disc encryption.
I'm always updating via terminal so I can see, what is taking so long.
Hopefully, that helped you.
Cheers
(02-22-2022, 10:34 AM)bujiraso Wrote: What are the average system update times for anyone else here?
It used to be discouraged to use "Software" and the Graphical User Interface for updates because it was known to cause problems (not sure if that's still the case). It was recommended to to use the terminal instead:
sudo apt update && sudo apt upgrade -y -y
That's how I've always done it without ever experiencing any problems or delays of glacial proportions. Never takes more than five minutes to upgrade (which I do on a daily basis though).
I've seen very slow initramfs creation with full disc encryption too. I update from the terminal not the gui.
It's also quite worth the time to alias Anna's tip to ~/.bash_aliases (or .bashrc )
alias sup='sudo apt update && sudo apt upgrade -y'
 that way all you need to do is run `sup` in your terminal if you find yourself unable to ssh in and have a tendency to fat finger the tiny popup keyboard.
Thanks, all, for the feedback!
I'll update via terminal, as suggested
  Mobian MMS/SMS text problem bcnaz 16 40,054 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,709 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,609 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,934 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,840 04-29-2025, 02:10 PM
Last Post: mdk
