Error - megapixels not opening
I am having some problems with a mobian isntall I did today, when tryting to open megapixels I get this error:
mobian@mobian:~$ megapixels Renderdoc not found Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini Adding camera rear from config Adding camera front from config Found postprocessor script at /usr/share/megapixels/postprocess.sh (megapixels:2559): Gdk-WARNING **: 22:08:12.230: gdk_gl_context_set_required_version - GL context versions less than 3.2 are not supported. Initialized OpenGL 2.1 ** Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1266:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5) Bail out! Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1266:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5) Annullato
What can I do?
Same here Cry   , since I've installed some Mobian updates and rebooted.
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(02-22-2022, 02:46 PM)dante404 Wrote: Same here Cry   , since I've installed some Mobian updates and rebooted.
I experienced this too. I manually fetched the package for megapixels 1.4.3 and installed that, and it's working again.
(Maybe this will cause me some problem I don't know about yet, I only just did it a few minutes ago.. But I did not have to install or upgrade any other packages to make it work, so I hope there will be no issues.)
-john
(02-22-2022, 10:33 PM)johns Wrote: I experienced this too. I manually fetched the package for megapixels 1.4.3 and installed that, and it's working again.
-john
Thank you for this info!
How did you do that? Fetched the source and compiled it yourself? Or is there a deb package of v1.4.3 anywhere?
-john
Just grabbed the deb package from http://ftp.debian.org/debian/pool/main/m/megapixels/
-john
I had the same problem. no need to download or reinstall things, just
sudo dpkg-reconfigure megapixels
and it should work again
@ johns : Thank you! It worked!  Smile
@ battlegarden : Too late for me, but thank you too!  Smile
On my phone the latest version works fine until there is a {bar,qr}code. The previous version marked it with a red rectangle and you could copy the content. The current version (1.4.3-1) freezes.
Can you reproduce this issue?
(02-26-2022, 12:51 PM)jsch Wrote: On my phone the latest version works fine until there is a {bar,qr}code. The previous version marked it with a red rectangle and you could copy the content. The current version (1.4.3-1) freezes.
I never tried on the old version, but I can confirm that with the current version, it freezes. It appears to lock on the QR code and then the image wobbles/vibrates and moving the camera no longer moves the image.
-john
I found a bug report matching this issue: https://gitlab.com/postmarketOS/megapixels/-/issues/45
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,694 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  pinephonepro.ini for Megapixels biketool 1 3,379 01-04-2025, 04:26 PM
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 4,072 08-30-2023, 03:59 AM
Last Post: karensather
  Megapixels doesn't work Glenn 4 8,094 08-28-2022, 03:19 PM
Last Post: vortex
  Megapixels and Pinhole Zebulon Walton 0 2,258 06-15-2022, 04:53 PM
  Flatpak error during apt update user641 0 2,642 02-14-2022, 08:35 AM
Last Post: user641
  Waydroid error: not using Wayland. But I am! quixote 7 14,430 01-09-2022, 02:47 PM
Last Post: jsch
  Installed Apps not opening mmd604 5 9,242 10-08-2021, 09:29 AM
Last Post: ragreenburg
  Enter disk decryption passphrase error healthyliving101 3 6,774 09-07-2021, 12:21 PM
Last Post: Fenellakw
  Video playback error (Totem/Videos) Zebulon Walton 0 2,334 08-19-2021, 05:37 PM
