My sound went away with calls... Not sure what happened. How can i fix it?
Hello. My sound is all of a sudden quiet when i try to make a call. I am running bookworm What do i do?
I'm not sure what i did. Some setting perhaps, or some update?
I have this unmet dependencies error in mobian also..
How do i troubleshoot and fix this? It's just quiet if i make a call.
Thanks you very much.
I first would try booting up on a freshly-flashed sd card and see if the sound problem persists.
(02-16-2022, 10:33 AM)usourypg3i Wrote: Hello. My sound is all of a sudden quiet when i try to make a call. I am running bookworm What do i do?
sometimes I have to turn on the speaker, then turn it off in order the hear the other side when I make a call, very ofter I call someone and hear nothing then that helps.
When I have trouble like that I sometimes can fix it by:
1) pressing the 'volume up' button a couple of times (during the call)
2) fixing the sound output in the settings, it may be stuck to 'internal speaker' or somesuch (not possible during call)
3) plugging-in headphones in the headphone jack - and unplugging it again! (during the call)
Best of luck
Appeared today for me, rebooting didn't change anything. However only outgoing calls seem affected.
  Calls 4G not working oliwierzgorniak 2 5,299 08-06-2024, 02:20 PM
Last Post: baptx
  Sound : notifications freelectro 6 8,010 06-07-2023, 01:03 AM
Last Post: freelectro
  No audio on calls after updating today Zebulon Walton 10 14,967 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
Exclamation No sound anonymous 22 25,286 11-08-2022, 09:07 AM
Last Post: dante404
  Chrony interrupts calls. jhasler 0 2,131 04-18-2022, 08:48 PM
Last Post: jhasler
  Lost all sound Dinosaur1946 0 2,768 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Calls : two rings and call cut and restore. Gribouille 0 2,141 01-14-2022, 07:40 AM
Last Post: Gribouille
  Sound design for Mobian S.E.B 4 6,752 12-27-2021, 05:40 AM
Last Post: Anna
Question Best Way of Receiving Calls Without SIM (VOIP) lovepine88 16 25,562 10-07-2021, 12:38 AM
Last Post: AndyM
  *urgent help*calls and gnome-conatcs gone after update user641 24 35,462 09-20-2021, 12:19 PM
Last Post: calinb
