Check Battery Level for Keyboard
I have error when trying read keyboard battery status:
ERROR: Proxy read failed with ff
OS latest Manjaro
UPD. Found issue - keyboard battery was fully discharged
(02-10-2022, 06:58 PM)Savrik Wrote: I have error when trying read keyboard battery status:
OS latest Manjaro
You will also get that response if you turn the battery pack off by holding the button on the side.
Is there any way to have the keyboard battery level appear in the status bar on Manjaro (Plasma Mobile) and to disable the on-screen keyboard automatically appearing whenever the keyboard case is attached?
(02-16-2022, 04:21 AM)arjan1995 Wrote: Is there any way to have the keyboard battery level appear in the status bar on Manjaro (Plasma Mobile) and to disable the on-screen keyboard automatically appearing whenever the keyboard case is attached?
You can't get the battery level in the status bar, maybe post that as an issue/idea for Plasma Mobile. As of right now, when running the commands given by Megi they don't even give a battery percentage. It is mostly useful to know if it is fully charged or full discharged. To disable the keyboard hold down on the home screen for a second or two then click "Add Widget" and one of the widgets will say something like "Input method" or something like that. Add that to your home screen and click it, that will disable your keyboard. Unfortunately on reboots it tends to disappear so you have to do it again. Though in all fairness, that is still faster than doing it on Phosh because Phosh also forgets the keyboard should be off.
Thanks, will try that later today.
After the latest update, i noticed that the keyboard is indeed listed in /sys/class/power_supply (like described above). No percentage, but has the voltage.
Interestingly, the keyboard only stops charging the phone when the battery is around 3.0v. Isn't that very low? And will that not damage / degrade the battery very quickly?
I don't know enough about hardware to know if that would be bad for the battery but I do know Megi mentioned that as being fully discharged in the FAQ, "If the reported voltage is very low (< 3 V) the keyboard battery is completely discharged."
I use such a cable for charging:
https://de.aliexpress.com/item/100500470...pt=glo2deu
It says how much power is drawn during charging. If the keyboard is fully charged, it goes to zero.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,391 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,066 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,929 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,607 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 26,816 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,381 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,031 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,229 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,119 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,886 06-29-2024, 09:36 PM
