Is there a way to delete APN settings ? I've got no sms support since i've set it up and would prefer sms over internet for now ...
Delete APN setting Arch-Phosh
02-09-2022, 11:26 PM
I believe you just add new APN settings +
Deleting them does not work
LINUX = CHOICES
**BCnAZ** Donate to $upport your favorite OS Team
02-10-2022, 06:08 AM
SMS worked out fine out of the box , but I Had no Internet , after setting up my carrier APN I lost Sms and got internet ... , Guess i'll flash back if it's what it takes
02-10-2022, 06:41 AM
In Phosh/ Mobian, leaving a blank in 'Regions & Languages' in settings 'used to cause problems' with the sms working, don't know if that is the case here.
Think it was maybe 5 or 6 weeks back I tried Dremurs/Arch/Phosh and voice, sms text, data worked then. -- I think hot spot was working, but I didn't take notes.
LINUX = CHOICES
02-10-2022, 09:42 AM
Not My issue ... I just want to delete the APN config , so basically I just need to know where phosh save that information and delete it
02-11-2022, 03:47 AM
https://www.freedesktop.org/software/Mod...cli.1.html This is one of the few ways I've found so far that you could probably achieve that. You can deactivate the connection in nmtui but if you want to delete it mmcli seems to be your best bet.
02-11-2022, 08:49 AM
Thanks will take a look at that , For now I returned to the stock image without APN setting , but if I could activate and deactivate it with a command I could be able to switch between Internet and SMS
