Disable on screen keyboard permanently.
OK my PinePhone is in the keyboard case. I go into "Settings --> Accessibility" and disable the on screen keyboard. On reboot the on screen keyboard is re-enabled even though the phone is still in the keyboard case.
Is there a way to disable the on screen keyboard so that I can turn it on and off manually but if I turn it off it will be off when I reboot?
Maybe a desktop icon that allows toggling the on/off setting ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
The problem I have had is similar but would require the same fix. I resize my desktop display to 175% to better fit all the icons onto the screen without scrolling. I use the apply to make the change but when the phone is turned off or rebooted the settings have not been saved. A permanent save feature would be helpful. Thanks for your comment. I have your same problem when I use my bluetooth keyboard with my phone. Each time I begin a new session with the keyboard I have to go to settings and disable the onscreen keyboard. Thanks for your comment.
(02-04-2022, 01:09 PM)gilwood Wrote: The problem I have had is similar but would require the same fix. I resize my desktop display to 175% to better fit all the icons onto the screen without scrolling. I use the apply to make the change but when the phone is turned off or rebooted the settings have not been saved. A permanent save feature would be helpful. Thanks for your comment. I have your same problem when I use my bluetooth keyboard with my phone. Each time I begin a new session with the keyboard I have to go to settings and disable the onscreen keyboard. Thanks for your comment.
Not sure what distro you are using, but you may be able to change the scale factor in /etc/phosh/phoc.ini. Change the setting under [outputBig GrinSI-1]. For example to "scale = 1.75".
For the keyboard, I have not tried this yet, but there is a script on this page: https://wiki.mobian-project.org/doku.php...ccessories
-john
Is there a simple command that can be issued at the terminal or via an on-screen icon that can toggle the on-screen keyboard on and off in Mobian? Having it active obviously makes for awkward use of the hardware keyboard. I don't necessarily need it to be permanently disabled but it would be nice to have a quick way to disable it with a single icon press.
Based on the script on the wiki page I guess something like this should work as the basis for a script which you could then add a .desktop file for:
if [ $(gsettings get org.gnome.desktop.a11y.applications screen-keyboard-enabled) = "true" ]; then gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled false; else gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled true; fi
(02-15-2022, 08:05 AM)wibble Wrote: Based on the script on the wiki page I guess something like this should work as the basis for a script which you could then add a .desktop file for:
Thanks, that works great!
What I did was use that in a shell script ~/bin/keybd, that displays the result before exiting:
#!/bin/bash if [ $(gsettings get org.gnome.desktop.a11y.applications screen-keyboard-enabled) = "true" ]; then gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled false; else gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled true; fi echo "" echo "" echo "" echo ====================================================="" echo "Toggling on-screen keyboard..." echo "Keyboard is now: $(gsettings get org.gnome.desktop.a11y.applications screen-keyboard-enabled)" echo ====================================================="" sleep 2
I installed xterm since I found that unlike King's Cross the xterm window closes completely after it exits (no need to swipe up).
sudo apt install xterm
Then I created the desktop file in ~/.local/share/applications/keybd_toggle.desktop:
[Desktop Entry] Name=04 Toggle Keybd Type=Application Icon=input-keyboard.png Exec=/usr/bin/xterm -fg white -bg black -e /home/mobian/bin/keybd Categories=Utility; X-Purism-FormFactor=Workstation;Mobile;
This makes for a very quick way to toggle the onscreen keyboard. (The reason for the number "04" in the name is to put this near the top of the screen. I have my most frequently used icons named that way, currently prefixed 00 through 04.)
-john
Thanks I'm running Mobian bookworm. Tried the edit of phoc.ini but the /phosh/phoc.ini does not exist under etc. Even tried to search the hidden files. I'm a Linux newbie so be kind but any assistance is appreciated. Thanks
(03-01-2022, 05:08 PM)gilwood Wrote: Thanks I'm running Mobian bookworm. Tried the edit of phoc.ini but the /phosh/phoc.ini does not exist under etc. Even tried to search the hidden files. I'm a Linux newbie so be kind but any assistance is appreciated. Thanks
https://wiki.mobian-project.org/doku.php...-variant-2
Right, forgot that you have to copy /usr/share/phosh/phoc.ini to /etc/phosh/phoc.ini to edit initially.
(Also know that once you do that, going forward after upgrades you may want to compare those two files to see if anything has changed in the /usr/share/phosh copy that you may want to also apply to your customized copy in /etc/phosh.)
-john
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,686 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Disable vibrations 3x5co 9 16,799 01-03-2026, 12:26 PM
Last Post: baptx
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,443 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,062 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,485 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,661 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,685 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 6,172 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 41,323 01-13-2025, 01:37 AM
  how to disable ipv6 at kernel level with towboot? vusra 3 5,194 10-04-2024, 04:23 AM
Last Post: vusra
