Browser cog - Problems on Mobian
Hello there,
the browser cog is a lightweight single window browser using WPE libraries. The problem is, that I cannot get the latest versions to run on Mobian - v0.8.1 is the last one functioning.
Has anyone here any ideas what could be the problem?
I tried the --platform= options, which result in errors that the libraries could not be found.
Thanks in advance!
Are you still on Bullseye (Debian Stable)?
A quick search of Debian packages shows that's the latest supported version in that release.
Cheers,
TRS-80
Protocols, not Platforms
(12-09-2021, 07:34 PM)TRS-80 Wrote: Are you still on Bullseye (Debian Stable)?
Thanks for your answer.
I'm on Bookworm and all the versions following 0.8.1 are not working.
I had the same issue and was dying without cog.  Building latest from source got it going again.
  1. uninstall existing cog version (sudo apt remove cog)
  2. checkout latest version from https://github.com/Igalia/cog (git clone "https://github.com/Igalia/cog.git")
  3. install dependencies (sudo apt install cmake build-essential pkg-config libcairomm-1.0-dev libwayland-client++0 libinput-dev libgbm-dev libdrm-dev libepoxy-dev libwayland-dev libwpewebkit-1.0-dev  libsoup2.4-dev  libgio3.0-cil-dev  libgio2.0-cil-dev  libwpebackend-fdo-1.0-dev )
  4. build and install:
  5. cd cog
  6. cmake .
  7. make
  8. make install
Did the trick for me, hope it helps!
  5. cd cog
  6. cmake .
  7. make
  8. make install
Thanks for the info! I will try that tomorrow.
Cog from Debian works again now Smile
I'm actually not using it anymore because I found Epiphany (GNOME Web) to be fast enough for most things and it has a nice way to create web apps from visiting a site.
  Printing from Mobian johnd 3 5,119 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,052 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,101 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,762 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,310 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,618 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 357,787 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,298 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,559 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,297 05-06-2025, 02:19 AM
