Pinephone Keyboard Doesn't Work
I received my PinePhone keyboard a couple of weeks back and my PinePhone Pro just arrived today.
The phone seems to work ok but the keyboard doesn't work at all.
I've tried rebooting, reseating, fiddling with the POGO connectors ... all to no avail.
Of note, the phone doesn't even appear to charge with a USB cable connected to the keyboard, but does charge when a cable is connected directly to the phone itself.
Could I possibly have a dud keyboard?
your case is exactly 100% the same as my situation.
yesterday I have opened the Pine Phone Pro package and the keyboard.
the keyboard is not working at all: no typing, no charging  nothing....
I tried to update from app store, update failed and gave me an error
I am so frustrated right now  Huh
(01-29-2022, 12:47 AM)ZX Spectrum Wrote: your case is exactly 100% the same as my situation.
Probably avoid using the app store to update, they both kinda suck for that. Try an update through the command line. If it is the default Pro image of Manjaro run, sudo pacman -Syu.
Good news!  I got it to work!
Apparently, it only works on stock PPP Manjaro (ie. no luck for me on Mobian, etc.) and only after you update the OS (which is as tricky as it is necessary).
Updating PPP Manjaro in the GUI is (like so many things) broken.  From another post (https://forum.pine64.org/showthread.php?tid=15868), in a terminal session enter 'sudo pinephonepro-post-install' and then enter 'sudo pacman -Syu' to get everything updated.
Note too that the keys (at least on my keyboard) require a hefty press to register.  So, be sure to press harder than you'd expect when testing them.
Clearly, the PPP is more of a hobby than a phone, at least at this point in time.
Same problem here. Keyboard not recognised by either mobian or manjaro. It does however act as a charger. If I press the on switch on the keyboard, the phone indicates it is being charged. But it does not respond to keystrokes.
Is this a bug with the hardware, or do you need to enable something in the OS to get it to work?
Just to be clear ...
The good news: I can now type using the keyboard but ONLY in stock Manjaro.
The bad news: charging the case battery and charging the phone with the case battery still does not work in any distro.
(01-29-2022, 12:12 PM)thismarty Wrote: Clearly, the PPP is more of a hobby than a phone, at least at this point in time.
There is tons of information all over the Internet about the current state of development of these devices. There are even a bunch of warnings all over the PPP store ordering page, some of them in bold red letters.
The fact that you ignored all of that, and decide to make such comments here reflects more poorly on you than on PINE64, IMO.
Cheers,
TRS-80
Protocols, not Platforms
Woah, settle down TRS-80.
I was just trying to be lighthearted about the nascent state of our mutual hobby.
Sorry you took it so hard.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,450 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,210 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,973 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,708 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 26,989 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,422 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,189 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  How to get the Rii 4 with 2.4 Ghz get to work with the PP Peter Gamma 1 3,313 07-18-2024, 10:48 AM
  Keyboards for the PinePhone? Peter Gamma 1 5,402 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,261 07-04-2024, 07:32 AM
