HDMI output problem
Bug
I found a weird problem that occurs when starting my Pine.
When I plug in the power i don't get any input on my TV.
To get the image showing I need to disconnect the HDMI cable and reinsert it (hotswap).
I have red in another thread here that hot swapping is NOT recommended with the Pine.
I have tried choosing another input on the TV and than back to the Pine, but this doesn't help.
Anyone else having this issue?
My setup is Pine A64+ 2Gb running Android 5.1.1 (Rooted) build 20160505
If anyone have a fix for this that would be nice. Or maybe I'll just have to wait for the next build to see if its fixed then.
(05-22-2016, 11:43 AM)Tarjei85 Wrote: I found a weird problem that occurs when starting my Pine.
Weird bug - have you reported it here ? I cannot help you unfortunately, but you are correct hdmi does carry a low DC charge and therefore could potentially damage equipment.
No I havent reported the bug there yet. Will do later today.
Thanks for the reminder.
One more question, does this happen with all images or just android?
I have only tried android, and it is only on the ××0505 image.
Not an expert (at all!) but could this be a HDMI handshake issue ?
I have no idea. I'm a noob when it comes to this. Will check it out and troubleshoot some more later. Thank you.
After some more testing. I got really surprised. The problem went away. Just suddenly. No idea what caused it.
Was changing HDMI-cables, power cables and psu with no luck, so when I gave up for the night and reconnected the settings I had when the problem surfaced, it was gone. I have not been able to provoke the problem to reaccur after that.
Good to know mate Smile that said ... very strange...
(05-27-2016, 04:33 AM)Luke Wrote: Good to know mate Smile that said ... very strange...
Yes in deed... now I just have to provoke the error so I can try to figure out what did it... *AndTheNextProjectIsBorne
  Pine 64 + WIFI - OVERHEAT problem Berkut 0 6,005 10-24-2018, 12:52 PM
Last Post: Berkut
  HDMI CEC on Android fneves 39 84,981 03-10-2018, 06:08 PM
Last Post: lupa18
  Can android 6.0 output spidf or coaxial if a buy the DAC? v1n1c1uS 0 3,367 03-03-2018, 10:40 AM
Last Post: v1n1c1uS
  USB Mic + HDMI Speaker jack_shepherd 0 3,338 11-27-2017, 03:27 AM
Last Post: jack_shepherd
  Android 6.0 (HDMI Video Output) [20170112 v2.0.1] no sound philips 0 3,998 07-23-2017, 11:14 AM
Last Post: philips
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,317 05-05-2017, 01:50 AM
Last Post: Quezbeme
  No HDMI Output Arkhanjel 5 10,404 05-03-2017, 09:21 AM
Last Post: Arkhanjel
  HDMI Color Inverted on TV Apicalis 2 10,436 03-28-2017, 10:33 AM
Last Post: lyhaku
  Supported 4:3 and 16:10 resolutions over HDMI on Android karlitos 26 55,577 03-06-2017, 03:59 PM
Last Post: dikov
  HDMI not working gubaguba 7 14,569 01-25-2017, 09:45 PM
Last Post: MakerLing81
