Pinephone pro Explorer teceived
Hi. I received today my Pinephone pro explorer. I installed I and found some advises and a little bit problem that I want to share with you. I already put then in pine64 telegram but I did not know about the forum. So I will put it here as well for you to know
I continue telling things
I started default installation and at the very end a message that there were updates
I click yes but I received and advise that no update was possible, the reason
Databases locked. A I am new to Linux I went to Google and ask or a solution and somebody gave it to me. " Shutdown, startup again and then
Open the terminal and write
Sudo pacman-db-upgrade && Sync
And " it worked" . Updated but with some warnings
That I will write down here for you to know and some help just in case
(01-27-2022, 10:28 AM)Emilio Wrote: I continue telling things
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 1,058 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,825 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 6,103 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 17,149 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,103 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,141 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 5,346 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,747 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,812 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 2,498 06-26-2025, 11:47 AM
Last Post: zetabeta
